Post by olivertwisted on Apr 28, 2016 16:38:12 GMT -6
OOPS! scratch those continuity reading! I'm getting used to my new meter so, I re -did the test with my old HF meter that I'm used to and got no resistance on those!
Post by olivertwisted on Apr 28, 2016 16:47:58 GMT -6
Oh HECK! I don't even know if I can trust my readings! I'll video and put it up, lol!
Post by Alleyoop on Apr 28, 2016 18:11:03 GMT -6
Those readings are good so your stator is good. So the only thing left is the CDI which cannot be tested just replaced.
Alleyoop
Post by olivertwisted on Apr 28, 2016 18:22:08 GMT -6
Okay, there's just too much folly involved, trying to get a video made, lol! So, let me just get a reality check on my test... With my meter set here, I get a 002- 003 reading. Does that seem right?
Post by olivertwisted on Apr 28, 2016 18:23:19 GMT -6
Okay, great! I hadn't seen your above post. Thanks alley, I'll replace it.
Post by olivertwisted on Apr 28, 2016 18:25:26 GMT -6
Hey, what's the deall on the "Performance" CDI.? Should I get that or just a stock one?
Post by Alleyoop on Apr 28, 2016 18:29:38 GMT -6
Yes, but that is not as important as the VAC readings you got WHICH ARE GOOD!!
So Your STATOR IS FINE.
I still believe it is a FUEL DELIVERY problem do this OLIVER:
You know where the fuel ratio mixture is on the carb?
FIRST with motor off TURN it clockwise until it stops and COUNT the NUMBER of turns it took to STOP. Then Turn it Back out Counter Clockwise the same number of turns. Now start it up and: First turn it 1/4 turns counter clockwise and wait for about 10 seconds and LISTEN IF THE IDLE went up or down. If it goes up keep turning the 1/4 turns UNTIL the idle DOES NOT GO UP OR THERE is NO CHANGE.
If the IDLE DOES nothing after turning 1 way 1/2 turn then go the other way.
YOU WANT TO GET THE HIGHEST IDLE out of that screw.
NOW if turning it left or right l/2 to 1 full turn does NOTHING then we have a problem. Alleyoop
Post by Alleyoop on Apr 28, 2016 18:35:22 GMT -6
The performance CDI's have the timeing advanced aabout 3% for us hotrodders just a tad more power, But on some motors with good compression it will kick back meaning the starter clutch slips and makes a nasty metal sound. So for you I would just get the OEM CDI. Alleyoop
Post by olivertwisted on Apr 28, 2016 18:39:34 GMT -6
OOOH, okay. OEM it is. Okay, I'll try to get that test done. I DO know where the A/F screw is and was trying to go through that when I got sidetracked. I'll try to get through that now.
Post by Alleyoop on Apr 28, 2016 18:52:22 GMT -6
Just remember you are trying to find the HIGHEST RPMS out of the mixture that is all. IF turning it in either direction does NOTHING then that means the PILOT JET and its passages are clogged. Alleyoop
Post by olivertwisted on Apr 28, 2016 19:24:23 GMT -6
Ok. I think that may be the case. Admittedly, my patience was very tried as I had to do gymnastics all over the place to contort well enough to get my little driver bit down in there each time. Everything else is too long to fit in there and my bit is too short to get a grip of, lolol! My neighbors must laugh, watching me out there! So, unless the changes I would hear are very , very subtle, I'm not hearing a change in rpms.
Post by Alleyoop on Apr 28, 2016 19:32:01 GMT -6
Post by olivertwisted on Apr 28, 2016 19:37:02 GMT -6
LOLOL!!! Thanks for the cheers! Yes, I am in my prime while doing elbow work rather than using my fibromyalgia fogged noodle! LOLOL! Yup! You've narrowed things down each and every time!
Post by Alleyoop on Apr 28, 2016 19:49:11 GMT -6
I just hope that is the end of it (LOL), remember you burned some of my brain with the SWITCH Yes I carry a screwdriver that is not to long and not to short and I get my hand UNDER the fender and look down through the trap door to see the carb and what I am doing (HAHA).
Post by olivertwisted on Apr 28, 2016 20:00:05 GMT -6
Oh gawd, PLEASE let this be the end of it, lol! Of the problem, NOT Alley's brain, I know, I gotta be careful what I ask for!
