Post by jct842 on Jun 3, 2016 9:31:04 GMT -6
I am going to bet the engine was at a whole lot more than 6k to break a valve spring. I am betting the tach is way off.
Post by rks on Jun 3, 2016 19:21:56 GMT -6
Let's see now......your poor little engine is breaking valve springs, but not reving over 6k, and you say all you want is to get 4,000 more rpm's out of it? ARE YOU FREAKIN SERIOUS?
Really hard for me to understand the way your mind works.
Stuck at 6k
by: bugnick4811 - Jun 7, 2016 6:12:18 GMT -6
via mobile
Post by bugnick4811 on Jun 7, 2016 6:12:18 GMT -6
Let's see now......your poor little engine is breaking valve springs, but not reving over 6k, and you say all you want is to get 4,000 more rpm's out of it? ARE YOU FREAKIN SERIOUS?Really hard for me to understand the way your mind works. My poor little engine is hitting 9k rpm where I want it and I'm running 56mph GPS verified now. I think my mind is working a bit better than yours. Thanks for the comment arse hat!
Stuck at 6k
by: cyborg - Jun 7, 2016 11:53:41 GMT -6
via mobile
Post by cyborg on Jun 7, 2016 11:53:41 GMT -6
We will help figure this out,,, let's not go into hostility,,, I have not reread the thread,,,,, but has the cam been replaced with one that has a higher lift?? Coil spring bind will break them,,, and also these machines have,,, ahem,,, quality control issues,,, may have just fatigued and broke on it's own,,, you do run it high rpm
Stuck at 6k
by: bugnick4811 - Jun 8, 2016 6:06:01 GMT -6
via mobile
Post by bugnick4811 on Jun 8, 2016 6:06:01 GMT -6
We will help figure this out,,, let's not go into hostility,,, I have not reread the thread,,,,, but has the cam been replaced with one that has a higher lift?? Coil spring bind will break them,,, and also these machines have,,, ahem,,, quality control issues,,, may have just fatigued and broke on it's own,,, you do run it high rpm Thank you sir, New cam and springs and 6.5g rollers seem to have fixed all issues. From my findings it's running better than most at this point. Rips like a raped ape!
Post by cyborg on Jun 8, 2016 7:24:50 GMT -6
OH GREAT!!!!! Good news!!!!!
