Post by scootermadness216 on Jul 3, 2016 12:41:38 GMT -6
Where do I install spark plug on a 2007 xingyue supercharge 150cc?
Post by jct842 on Jul 3, 2016 13:34:46 GMT -6
Go to the library here and read. Generic service and owner manuals are there. Your engine number is on the engine case near the kickstand mount. You will have to remove plastic. The spark plug is in the head of the engine. When you locate it and go to put the new one in be very careful to not over tighten. The head is soft aluminum and will strip if you over tighten. Just enough force to crush the washer on plug.
Post by rks on Jul 3, 2016 14:35:02 GMT -6
I might add...... install your plug using just the socket and your fingers until crush washer makes contact with the head, then use the ratchet handle to snug it down. It is very easy to cross thread these, if you just start them a turn or two, and grab the ratchet.
