Post by natedoggaz on Feb 21, 2017 13:11:57 GMT -6
Hello, I recently purchased and installed a new GY6 engine. 150cc / 157QMJ I have everything almost all connected up - except for the stator. The 3-wire connector on the new engine (yellow, green, and white wires) will not connect to the current wiring harness. The plastic plug connectors are different... Is it as simple as cutting off the current plastic connectors and getting 2 new male and female pigtail connectors, soldering/splicing them on and then connecting it all up? Any suggestions would help... FYI - here is what I got just in case: www.amazon.com/gp/product/B01A6M2ZN6/ref=oh_aui_detailpage_o01_s02?ie=UTF8&psc=1Thanks!
Post by cyborg on Feb 21, 2017 17:22:13 GMT -6
I'd go with the new plug route myself,,,in case there's trouble down the road it's an easy replacement
Post by natedoggaz on Feb 21, 2017 17:48:13 GMT -6
Great - thanks!
I have confirmed that the stator is A/C (5 wires) and the CDI should also be A/C - it is quite small. I also have 5 wires going to the CDI (3 and 2) so will just solder the new pigtails I bought onto the stator and harness.
The new pigtails are rated at 300/500v and a max of 10amp (AC or DC) so should be plenty enough..
ND
Post by cyborg on Feb 21, 2017 21:07:33 GMT -6
Go and let me know how it goes
