Post by budthatsmyrealname on Mar 28, 2018 18:36:52 GMT -6
I have a hose that is hanging and i have no idea where it goes to. I dont know how to upload a pic but ill describe best i can
its a black rubber hose coming out of the engine. located by the rear shock also right next to the rear brake cable mount
if i let it hang and i let it run, then the area gets wet with oil. I dont think it had anything to do with the engine because its in the rear. Only thing i can think of is, its a vent hose for the rear gears
I googled qmj157 and i see some engines have it but doesnt clearly show where it goes
where does it go and what is it? Thanks.
Post by cyborg on Mar 28, 2018 23:37:02 GMT -6
Could’ve aren’t hose off the air box,,,
Post by czmdiver on Mar 29, 2018 6:02:28 GMT -6
That hose is the Rear Gear Final drive Vent hose... It just hangs and vents thats all. See the hose on my GY 150. click on the image to see better I just stuck mine in the unused second location for a rear shock bearing just to keep it out of the way.. If it is leaking Oil she maybe overfilled, check the Rear Gear Oil level... I change my reear gear oil every riding season and have never had any issues..
Post by solymar on Mar 29, 2018 10:48:52 GMT -6
On my TaoTao it goes from the top of the valve cover to a vacuum T, which also connects a vent tube from my airbox hose. Both of those then go the to line your talking about (cvt vent hose).
Hope that helps!
Solymar
