Post by natedoggaz on Apr 23, 2018 11:01:30 GMT -6
Hey all, Having a major issue with my scoot blowing fuses. The battery fuse (10a) keeps blowing or wanting to blow... I have disconnected virtually everything - all front lights, all tail lights, starter, CDI, solenoid, voltage regulator...etc... And the battery fuse wants to blow just by turning on the ignition..! I would put my hand on the fuse and when it stars to get warm, I switch it off. The only thing I found that stopped the scoot from wanting to blow the fuse was when I disconnected the STATOR. I started snipping wires (5 wire stator) and spliced them back until I found the culprit. The wire that made the fuse want to blow was the yellow stator wire. With the other 4 wires still connected (white and green, and the other 2 separate wires) the fuse did not want to blow... Is it possible I have a bad stator that is causing these issues?? ...Or any thoughts would be much appreciated... Thank you!! ND Read more: itistheride.boards.net/thread/10592/150cc-jonway-keeps-blowing-fuses#ixzz5DW2mWpe1
Post by cyborg on Apr 24, 2018 7:24:57 GMT -6
Over charging,,I would think the regulation is the culprit,,,
Post by natedoggaz on Apr 24, 2018 12:33:24 GMT -6
man... what a total P.I.T.A. - found the culprit... !!
A yellow wire going to the stator - and a few other things - somehow shorted out and fused with what appears to be a black ground wire...
The trick I used was to turn on the ignition for maybe 5 seconds - which gave enough time for the wires to get warm before the fuse blew. I just felt around for those warm wires and followed them to where the short was...
I cut out the short and spliced the wires back together.
Starts up great and runs now!
ND
Post by cyborg on Apr 25, 2018 8:14:39 GMT -6
Nice find!!! There's a piston right there
