Post by johnattaadiku on Jun 26, 2023 3:19:40 GMT -6
My 50cc keyway scooter can not start when ignition key is turn on the ignition light 🚨 very low and scooter can't start. When I put it on the stand the scooter can start but when I move it down 👇 from the stand ignition light goes off and engine stops. Can anyone help me. Thank You
Post by classacted on Jun 26, 2023 12:50:59 GMT -6
as soon as the engine stops, check for spark. you may need someone to hold the bike. you may have a switch connected to the stand, if I am understanding you correctly.
Post by johnattaadiku on Jun 28, 2023 3:42:27 GMT -6
Thank You. I have checked under it but no switch. I have charged the battery 🔋 when on stand ignition 🚨 comes well Bright now when I start engine with kickstart engine start very Good 👍 when accelerating everything is fine but when I move it from stand engine goes off ignition light comes dim or comes and go. But when I put it on stand again everything works fine. I need help why so what must I look for. Thank You
Post by classacted on Jul 1, 2023 14:05:00 GMT -6
I definitely recommend having spare ignition parts. with my bike, it's quicker to swap a part (I would recommend you to swap the coil NOW if you have one, I suspect the spark plug cap inners are moving around, or you're losing contact along the way, also, those on the back of the coil come loose), than it is to actually diagnose with a tester. also, check the plug while you're at it, although this doesn't sound like a plug failure. certain wires from the stator, cdi, and coil are suspect. I also suspect a ridiculous hot wire somewhere in the bike is suddenly grounding out due to movement. if you still have all of the faring on the bike, you may need to remove it to fix this.
Post by classacted on Jul 1, 2023 14:09:04 GMT -6
check the spark when it's on the stand and test it when it's off the stand you want to be sure if it's a spark issue
Post by kz1000st on Aug 1, 2023 16:27:00 GMT -6
Check the wiring. When you say "off the stand" do you mean side stand or center stand. If it's the center stand a wire may be dislocated when it hits the ground. Or it has a bare spot that grounds out or the ground wire from the engine to the frame is pulling off the ground bolt.
