Post by brndnpnt on Dec 4, 2010 20:13:37 GMT -6
I need to use your brain again.. Ok. This is what I am working on. I have a speedometer cable and I know how to connect it and where It connects to. BUT! On my front tire there are two bolts A Big on the brake side and a smaller one on the other. I got the small one loose but did not back off far because the bolt does not come back but tightens so I left the scoot like she is until I hear back from you on what I need to do to get to the speedometer. I would guess the shock swings out of the way or I may have to unbolt it. I also am guessing that the other bolt on the front tire will hold it up? ?? I need big time help thanks.... Thanks Brandon Ponthier tbx260 257cc
Post by tvnacman on Dec 5, 2010 7:03:59 GMT -6
brn can you post two pics one of each side
Widehide and the Wife
Post by widehide on Dec 6, 2010 8:50:20 GMT -6
brnd...Yes the axle bolt still in the wheel and right shock will hold the scooter up. What I have done is to put the scooter on the center stand, if you remove the front axle from the wheel the weight of the scooter should shift to the rear and the rear wheel will touch the ground, the front will not drop forward and down. To test this have a second person with you to press down on the rear as you remove the front wheel. On my wifes 54b I placed heavy weight in the tour box to be sure it kept the rear down and the front up.
2009 Jonway YY250T-2 aka Bali 250cc
Post by fairweasel2323 on Dec 9, 2010 19:35:27 GMT -6
need pics my speedometer cable just screws in on right side under the brakes?
Post by fairweasel2323 on Dec 9, 2010 19:36:25 GMT -6
shouldnt have to take tire off to replace it unless im not understanding something here?
Post by Alleyoop on Dec 9, 2010 19:59:36 GMT -6
If your just replaceing the Cable then it should be pretty simple here is mine all I do is unscrew the screw that is holding the cable in and pull it out. Alleyoop
Post by widehide on Dec 10, 2010 8:19:24 GMT -6
Yes guys he will need to pull the axle out of the left fork tube and then rotate the lower leg of the tube. The reason is he has the fork with the axle mounted on a stud in front of the tube, not in the center/bottom. The tube is blocking access to the screw that retains the speedo cable. He probably has it figured out by now. Adios
Post by royldoc on Dec 10, 2010 9:57:39 GMT -6
Doesn't the speedometer go on the axle and not the tire? Sorry, had to. ;D Good luck with this. Roy
Post by brndnpnt on Dec 21, 2010 17:58:22 GMT -6
Sorry it took so long to get back... Yes thank you for all of yalls input... My screw for my speed o meter was faceing down with the shock not out like in the picture so i canged my speed o cable when I changed my front tire this weekend..... I would like to add the 400 miles back to my meter some how.
