Post by skytex on May 21, 2011 10:05:31 GMT -6
Ok, next on my list is that my front brakes squeel loudly, but only after it has been used a couple of times. I checked out the pads and they seem fine. lots of meat there. fluid level is fine. any ideas?
Post by Alleyoop on May 21, 2011 10:24:38 GMT -6
So the jumping and whatnot was just the Loose Wheels? Alleyoop
Icebear Trike 150-9
Post by Triker98304 on May 21, 2011 16:18:10 GMT -6
Skytex You might try cleaning the front brake disc. Sometimes the road oil gets on them and causes a squeak. Next take the pads off and check for hot spots like you get on your car when they overheat. Here in the mountains I check mine often. Triker98304
Post by skytex on May 21, 2011 20:07:41 GMT -6
Dunno yet alley, blasted storms have kept me from riding today. I did however take both rear wheels off to find both castle nuts loose. I added a washer each, tightened them down, and put new pins in them. It didn't do it on the trip around the block I took. I"m just tryin to knock out everything while it's down.
Post by Alleyoop on May 21, 2011 21:24:05 GMT -6
Well if it didn't do it around the block that was it, Just loose wheel hubs. Alleyoop
