wont start
by: brian15295 - Jun 19, 2011 13:08:10 GMT -6
Post by brian15295 on Jun 19, 2011 13:08:10 GMT -6
Went to start my scooter today will not start. I have power, alarm works turn signals work. I turn the key hold the brake and push the button and nothing? any suggestion what it might be?
wont start
by: speedracer - Jun 19, 2011 13:19:54 GMT -6
Post by speedracer on Jun 19, 2011 13:19:54 GMT -6
What model scooter? It could be the switch on brake handle. Does rear brake light come on? Does your scooter start no matter what brake handle you use? Kill switch off?
Need more info.
wont start
by: brian15295 - Jun 19, 2011 14:19:46 GMT -6
Post by brian15295 on Jun 19, 2011 14:19:46 GMT -6
model scooter is roketa 250 54b. it is not the the kill switch. I tried both brake handles and still wont start
wont start
by: Cruiser - Jun 19, 2011 20:20:03 GMT -6
Post by Cruiser on Jun 19, 2011 20:20:03 GMT -6
I am assuming the starter is not turning. Try momentarily bridging the two large terminals on the starter relay with a screwdriver to see if the starter spins over. If this doesn't work, then you either have a bad battery or a bad starter.
If this does work, then let us know and we can start troubleshooting the starter circuit.
wont start
by: brian15295 - Jun 19, 2011 21:35:50 GMT -6
Post by brian15295 on Jun 19, 2011 21:35:50 GMT -6
can it be a loose wire or connection, fuse up near the switch? How hard is it to take apart the bike to look at the wires
wont start
by: speedracer - Jun 20, 2011 8:38:39 GMT -6
Post by speedracer on Jun 20, 2011 8:38:39 GMT -6
On the cdi make sure the 2 wire connector is connected. Next the coil has a rubber boot on it. Remove and make sure both wire connectors are clean and secure. Do what Cruiser suggested to check starter.
