Post by speedracer on Jun 4, 2012 19:15:00 GMT -6
How old is the battery? I would take the scooter to a auto parts store and have them do a load test on the battery. Your voltage seems low to me. Mine is 13.04 without starting it and 13.75 at idle.
Post by speedracer on Jun 1, 2012 19:07:56 GMT -6
Great going Richard. Lets get our scooters up to 20000 miles.
Post by speedracer on May 30, 2012 12:27:26 GMT -6
Richard, at least once a month I can take my screwdriver to the intake clamps and get another out of it. I really should replace that clamp like you did. Yes, vibration can loosen clamps.
Post by speedracer on May 28, 2012 14:51:59 GMT -6
I use my scooter most of the time. Only really use the car if it is raining or we are going on a trip, otherwise it's scooter time. Sure had my fun fixing things, but it has yet to shut down and not refire. It's up to 12,000 miles now and it starts right up every day. I'm sure something else will go, but keeping my fingers crossed in the mean time. Good for you Nulldevice. Keep on scooting.
Post by speedracer on May 25, 2012 17:17:27 GMT -6
Good news Richard. Seems like it running good once again.
Post by speedracer on May 23, 2012 10:21:50 GMT -6
The picture you just posted looks fine to me. Sure looks like it getting the right amount of air and gas.
Post by speedracer on May 21, 2012 17:22:32 GMT -6
Too lean is right. although picture isn't too clear. Looks like the tip is white as well. Go back the 1/2 turn and run it for 20 miles then check it again.
Post by speedracer on May 16, 2012 16:59:58 GMT -6
I should have said before replacing the coil if there is no spark. Check the two wires which connect to the coil from the CDI. One just may have come off and there sure would be no spark.
Alley, wouldn't he have some warning signs before it just flat out and died if the valves were off such as stalling and poor starting?
Post by speedracer on May 16, 2012 15:36:43 GMT -6
If there is no spark then start thinking of replacing the coil.
Post by speedracer on May 13, 2012 20:22:38 GMT -6
Take your fuse out and go to any auto parts store and they will find the right one for you.
Post by speedracer on Apr 24, 2012 14:41:51 GMT -6
No one mentioned the stator at all. Since he can only start it after the battery has been charged it could be his stator isn't charging the battery. I would test the volts on the battery when the engine is running and see what it measures before removing the entire rear plastic panels and trunk.
Post by speedracer on Apr 16, 2012 18:44:13 GMT -6
lceel, I would check again with the engine you have on your scooter as it is not the same engine that is installed on the 54b. I believe you may have the Honda clone engine. Jct is right about the headlights. They are on the left and starter button and kill switch is always on the right side.
Post by speedracer on Apr 15, 2012 19:05:29 GMT -6
The plastic tank is your overflow tank and it's right next to the gas cap. That hose runs to the radiator cap. When your engine is hot it will push fluid to that plastic tank via the hose and when it cools down it can draw fluid back to the cooling system. The wire you are talking about also feeds the fan on 54B which you say you have. On my scooter the wire is white and runs under the belly, splits to the fan then continues on the R/R.
Post by speedracer on Apr 12, 2012 10:22:15 GMT -6
lceel Your overflow tank is under the gas cover lid which needs your key to open. I can't even think of a thick hose which would be next to your front wheel. You should take a picture of it and post it here. Behind the front wheel is the radiator and there are no hoses which go towards the front wheel.
Post by speedracer on Apr 7, 2012 14:22:52 GMT -6
Your system just may have air in it, which will cause it to run hot and not allow the fan to come on. Flush and air evac.
