Post by LUKE on Sept 16, 2011 22:54:44 GMT -6
what do you think about this trike: yay? or nay?...i know someone here will say nay...
Post by royldoc on Sept 16, 2011 22:58:27 GMT -6
A low rider trike LOL.
Roy
Post by trevnar on Dec 27, 2011 17:32:04 GMT -6
Hay guys new to this trike world just picked what i think is a Hozhou daixi zhenhua ZH-50X and i was told it was upgraded to a 75cc honda engen cant seem to find anything on it what do u all know about it ?
Post by Alleyoop on Dec 27, 2011 17:59:19 GMT -6
Here are the specs on that ZH-50X Trike: Alleyoop STROKE(³å³Ì£© FOUR STROKE Cylinder Arrangement£¨Æø¸×£© SINGLE CYLINDER Bore x Stroke (mm)£¨¸×¾¶ X Ðг̣© 39mm*41.5mm Piston Displacement (cc) £¨ÅÅÁ¿£© 49.5 Compression Ratio£¨Ñ¹Ëõ±È£© 10.5:1 Maximum Power (kw/r/min) ×î´ó¹¦ÂÊ 2.1/8000 Maximum Torque (N.m./rpm)×î´óŤ¾Ø 3.1/6500 Starter System £¨Æô¶¯ÏµÍ³£© telectric start/kick star Lubrication È󻬷½Ê½ Pressure and splashing Transmission ´«¶¯ CHAIN Overall Length (mm)×ܳ¤¶È 1950mm Overall Width (mm)×Ü¿í¶È 1010mm Overall Hight (mm)×Ü¸ß¶È 1120mm Wheel Base (mm) Öá¾à 1500mm Seat Hight (mm)×ù¸ß 790mm Ground Clearance (mm)ÀëµØ¾àÀë 70mm Dry Weight (kg)¾»ÖØ 119kg Fuel tank(L) 4.5L Brake (Front/Rear) Ç°ºóɲ³µ DISC Tyre, Front Ç°ÂÖ 110/90-10 Tyre, RearºóÂÖ 205/50-10 Ignition Typeµã»ðÀàÐÍ CDI Battery µç³Ø 12V/7A cooling system Àäȴϵͳ AIR-COOLER clutch ÀëºÏÆ÷ CVT gearsµµÎ» AUTOMATIC Packing size°ü×°³ß´ç 192cm*87cm*120cm Max Speed×î´óËÙ¶Èkm/h 60 You can also see it here IB imports them: www.icebearatv.com/PST50S-12.com.htmThat is a nice 50 Trike that can do 40mph out of the crate, since they are heavier than a 2 wheeler. So it must have oversize piston in it. It would be easy enough to get it to reach around 50mph ;D
Post by trevnar on Dec 27, 2011 18:18:47 GMT -6
Very sick thanks man thats the one im having a problem starting but when it starts it seems to idle fine and it stalls out after little when u get on it and it maxis out at 35 ish duz that mean its running lean ?
Post by Alleyoop on Dec 27, 2011 18:44:18 GMT -6
Yes, most likely it is running lean, they set them Lean to pass emission tests . And then on a lot of 50s they put a plug over the Fuel Ratio Mixutre screw so people do not mess with it, but that usually causes them to run like crap. I hope it has a carb that the Fuel Ratio Mixture screw is NOT capped, otherwise you will have to drill out the Plug to get at the Fuel Ratio screw behind it.
Take a picture of your Carb BOTH sides to see what kind of setup you have and we can then work on adjusting the Carb. Alleyoop
Post by trevnar on Dec 27, 2011 19:17:07 GMT -6
Ok heres the carb Attachments:
Post by trevnar on Dec 27, 2011 19:18:32 GMT -6
Other side Attachments:
Post by Alleyoop on Dec 27, 2011 19:41:28 GMT -6
Well cannot see enough of it HERE is what we are looking for Look at the Fuel Ratio Screw on this 24mm carb yours is just smaller most likely a 18mm. See if you have the Fuel Ratio on yours exposed. Alleyoop This is the LEFT SIDE where the Fuel Ratio Screw is: This is the RIGHT SIDE:
Post by Alleyoop on Dec 27, 2011 20:01:36 GMT -6
Post by trevnar on Dec 27, 2011 20:05:07 GMT -6
This Attachments:
Post by trevnar on Dec 27, 2011 20:19:35 GMT -6
And what is that black box that the fules going in to ... Nvm thats vacuum stuff Attachments:
Post by Alleyoop on Dec 27, 2011 21:15:49 GMT -6
Yep, your Fuel Ratio screw is CAPPED(BUMMER). You will have to drill into the center not to deep maybe just 1/16 to an 1/8 depending if its a CAP or A PLUG. Then just get a small screw and screw it into the hole you drilled just enough so it grabs and pull it off. Some just get the same CARB but with the Fuel Ratio Screw NOT CAPPED. They sell them for aaround $30.00 bucks.
The black boxes and canisters you see are the emission crap the put on them. Many just take them all off because sooner or later they will cause problems with starting and the motor running right. Alleyoop
Post by trevnar on Dec 28, 2011 11:45:23 GMT -6
Hay man think i figured out the plug boot was messed up got a new one and then sea foamed it still has ishew starting but i think it might be the sea foam but it dusnt stall anymore
Post by trevnar on Dec 29, 2011 17:31:37 GMT -6
I think it may be seezed now was riding cut out and herd a big clunck :/
