Post by ironworks on Oct 7, 2011 23:23:40 GMT -6
does anyone know what type and amount of fliud goes in rear differential on a 2010 ice bear 300cc compellor
Post by royldoc on Oct 7, 2011 23:30:00 GMT -6
When I drained mine it had about 10 oz in it. The gear box also has about 10 oz. I refilled with 80w-90 synthetic gear oil. 10-12 oz will be good.
Roy
Post by Alleyoop on Oct 7, 2011 23:46:56 GMT -6
Yea they don't take much since it is a SPLASH system so a little goes a long way. Alleyoop
Post by leenark on Dec 8, 2011 9:17:22 GMT -6
Right on about the amount. Anything more will cause a leak via the overflow hose. On the 300 there are 2 ways you can fill it both are from the top of the differential. Be careful that you don't strip the refill bolt on top. It's aluminum on aluminum.
Post by mike6736 on Dec 8, 2011 9:52:31 GMT -6
Mine was stripped out when I got it. Lee it turned cold here yesterday at 2pm.. We are only in the 60 today
Mike
Post by Alleyoop on Dec 8, 2011 14:31:01 GMT -6
Turned cold 60 degress!!! Man that is a heat wave compared to here, tonight down in the single digits 5-8, today in the 20s windchill in the teens BURRRRRRRRRRRRRR. Alleyoop
Post by mike6736 on Dec 8, 2011 14:42:24 GMT -6
Lee can tell you I had mine over filled, we changed it out at his place. I think I put in 8oz when I changed and put new gear box on than when I was putting on the tires I think I forgot I did it and put another 8oz in. Remeber all the oil on the floor of the truck? Was coming out the grease seals.
My mind some times, think I pulled the hammer back to fare on too many times
Mike
