Post by smokingmango on Mar 15, 2012 8:04:24 GMT -6
I am needing to get one of these for my SC150 Baja scooter. But i am unable to find one by looking up the part number. Anyone have suggestion where to find it?
Post by Deleted on Mar 15, 2012 8:25:15 GMT -6
Drive Gear arse?? i do have parts for your scooter on my site but mine are Performance Parts. if your looking for stock i think you can check Partsforscooters.com or Mainelyscooters
Post by smokingmango on Mar 15, 2012 8:53:25 GMT -6
Thanks for the links, when i went to your site, i found what i really need to replace. It is the drive plate i broke 2 of the blades on it. So would i still need to replace the whole variator or can i just replace the drive plate?
Post by silverfox96 on Mar 15, 2012 9:22:14 GMT -6
check the face of the variator! If it's gouged or damaged, replace the entire variator. You might want to install a 115mm setup, but check to be sure you have the room for it.
Post by silverfox96 on Mar 15, 2012 9:23:56 GMT -6
scooterelements; I think he was abreviating the word assembly!LOL
Post by Deleted on Mar 15, 2012 10:16:04 GMT -6
scooterelements; I think he was abreviating the word assembly!LOL ohhhh hahahaha i was like HUH???
Post by Deleted on Mar 15, 2012 10:19:57 GMT -6
check the face of the variator! If it's gouged or damaged, replace the entire variator. You might want to install a 115mm setup, but check to be sure you have the room for it. all of mine are 114.3mm and yea i agree with your statement if its damaged its best to replace the system. i do have this little combo. The only thing is the Drive plate is a lightweight drive plate and its bigger than the factory one. It runs about double what the factory drive plate is tho. but they are racing at both being 114.3mm scooterelements.ecrater.com/p/13066301/polished-racing-variator-combo
Post by Random Hero on Mar 15, 2012 11:05:25 GMT -6
You should count the splines on the baja before you order parts...When i was helping Jay on his trip we found out that BAJA uses a different size shaft on the rear gears. After that happened we where very careful to measure before ordering. PFS has a section dedicated to Baja..try them out.
