CVT noise
by: jerundax - May 26, 2012 19:31:04 GMT -6
Post by jerundax on May 26, 2012 19:31:04 GMT -6
Well I have a problem. I took a low speed spill on the scoot a week or two ago. No real damage I thought. Lost a mirror and had some scratches. Now though when I hit over 30 mph I start to hear a pulsing grind from the cvt. I think the small gear above the variator may be rubbing on the gear face of the variator. This is a 50cc Sunny clone short case. I think I have the picture attached of the scooter now.
CVT noise
by: Alleyoop - May 26, 2012 20:09:58 GMT -6
Post by Alleyoop on May 26, 2012 20:09:58 GMT -6
That is the BENDIX, if you notice the shaft sticking out on the Bendix FITS into a SLOT on the CVT cover. So if you did not LINE up the BENDIX SHAFT into the HOLE in the CVT cover it will be riding on the Variator Fan pulley. Take a picture of the CVT area by the Variator. It probably looks like this: Alleyoop
CVT noise
by: jerundax - May 27, 2012 8:17:12 GMT -6
Post by jerundax on May 27, 2012 8:17:12 GMT -6
Ok thanks for the help. Is there an easy way to ensure I have it lined up right? I don't have a lot of experience with these this is my first scooter.
CVT noise
by: Alleyoop - May 27, 2012 12:12:48 GMT -6
Post by Alleyoop on May 27, 2012 12:12:48 GMT -6
Here is what I would do if I had trouble lineing it up. I would drill a small hole in the center of the CVT where the shaft fits into and then Paint a White or Yellow or something on the Center of the Shaft this way if you see the color through the hole from the outside you know it is in there. Alleyoop
CVT noise
by: jerundax - May 27, 2012 20:25:24 GMT -6
Post by jerundax on May 27, 2012 20:25:24 GMT -6
Ok worked on it today. Pretty sure its in but still getting a grinding noise at higher speeds and climbing hills. Now I'm thinking rooller out of place or a clutch spring loose. Haven't been able to check because I don't have an impact wrench. May have to wait till I can buy one.
CVT noise
by: sprocket - Jun 2, 2012 15:20:55 GMT -6
Post by sprocket on Jun 2, 2012 15:20:55 GMT -6
Also check other things like center stand etc..if you dropped the scooter you may have something loose that is vibrating at speed...it may sound like the Cvt but could be something else..
CVT noise
by: jerundax - Jun 6, 2012 21:27:10 GMT -6
Post by jerundax on Jun 6, 2012 21:27:10 GMT -6
Ok Sprocket are you psychic as well as great at scooter repair? Did a complete inspection and found the inside spring on the center stand had come loose. Didn't realize there were two springs. Had my preteen sons help with the repair great bonding time. Noise is gone thanks Sprocket and Alley for all the help.
CVT noise
by: sprocket - Jun 12, 2012 20:44:08 GMT -6
Post by sprocket on Jun 12, 2012 20:44:08 GMT -6
Good find...
