Scooter Doc
Post by sprocket on May 8, 2013 21:34:56 GMT -6
It is probably the float needle...the rubber tip might be missing, or broken, etc...
Scooter Doc
Post by sprocket on Dec 22, 2012 15:24:39 GMT -6
Just checking in to wish everyone a very Merry Christmas or whatever turns your crank!
Keep the rubber on the road! ;D
Scooter Doc
Post by sprocket on Oct 22, 2012 18:39:34 GMT -6
Replace the plastic T In the vacuum hose layout..they frequently go bad and you loose vacuum..petcok could be getting..I would jut replace it...
Scooter Doc
whhich CDI?
by: sprocket - Oct 22, 2012 18:35:47 GMT -6
Post by sprocket on Oct 22, 2012 18:35:47 GMT -6
Yup..NCY...better components and more dependable
Scooter Doc
Post by sprocket on Oct 19, 2012 13:59:53 GMT -6
The washer under the nut on the starter clutch only goes on one way...mark it before you remove it, so you know which side faces the nut.
Get it on backwards and you will have nothing but problems...
Scooter Doc
Pilot Jet
by: sprocket - Oct 19, 2012 13:54:22 GMT -6
Post by sprocket on Oct 19, 2012 13:54:22 GMT -6
Use a fuel filter designed for gravity feed systems, like for a generator, snowblower, riding mowers etc. Automotive filters don't work well on scooters
Scooter Doc
Post by sprocket on Oct 19, 2012 13:42:26 GMT -6
Sound to me like you are a link out on the timing chain...
Scooter Doc
Post by sprocket on Oct 8, 2012 17:56:36 GMT -6
Check the filter is in the line the right way..reversing it is a common mistake and it won't run well if backwards..
Scooter Doc
Post by sprocket on Oct 8, 2012 16:06:13 GMT -6
Check that the case pointer of the flywheel is close to the 'T' mark on the wheel...or the cam sprocket marks are aligned to the head, with the large hole at the top...
Scooter Doc
Post by sprocket on Oct 8, 2012 16:01:33 GMT -6
You have a short to ground somewhere.. get a cheap multimeter and start checking... likely the switches on the handlebars, they are very susceptable to water... but it could be anywhere...
Scooter Doc
Post by sprocket on Oct 7, 2012 14:10:39 GMT -6
Did it run before you got it? Could be the carb needs cleaning, if it has been sitting with gas in the tank..
Scooter Doc
Post by sprocket on Sept 25, 2012 14:01:58 GMT -6
Sorry to hear about your problems...the engine is done. I don't think the shop is responsible, but maybe you can cut a deal on a new one...
Scooter Doc
speedometer
by: sprocket - Sept 25, 2012 11:33:33 GMT -6
Post by sprocket on Sept 25, 2012 11:33:33 GMT -6
Sounds like this guy is having a speedo meltdown...its a speedometer...
Scooter Doc
Post by sprocket on Sept 25, 2012 11:28:55 GMT -6
Most 4 valve heads have aggressive cams...yup...you need to change the piston to,match the head in many cases...do a carefull wax test, by hand after you torque down the head..you likely will need to machine the piston head...
Scooter Doc
rear tire
by: sprocket - Sept 25, 2012 11:14:45 GMT -6
Post by sprocket on Sept 25, 2012 11:14:45 GMT -6
You will also need breaker bar or an impact wrench...
