Post by xanthakita on Jun 17, 2012 20:06:22 GMT -6
Hi all, sorry for no introduction but I need answers first then I'll introduce myself.
My son has a 150cc motorcycle(scooter) the other night he was driving home when it suddenly stopped running and gasoline started spewing from the overflow.
I did some research and found that it was likely a stuck float valve. We disassembled the entire carb. and found the float valve to be working. we even tested by blowing air through the fuel inlet valve and with the float closed no air went through but when we opened the valve air passed. while we had it open we made sure everything was clean (it only has about 700-800 miles on the engine).
I told my son it could have been water in the fuel that stuck the valve but that we probably would never know.
We reassembled the carburetor. checked the petcock to make sure it was functioning properly even replaced the spark-plug to be on the safe side.
After reassembly I got the bike running, but fuel was spraying out of the overflow while it ran, and now it's doing the same exact thing it did in the first place.
We are desperate.. any ideas suggestions etc would be greatly appreciated!
Thanks, Jonathan
Post by Cruiser on Jun 17, 2012 20:45:42 GMT -6
Welcome to the forum, Jonathan. A gas leak like you describe is usually caused when the screw at the end of the carb drain hose comes out. Here's what the hose which is located on the bottom of the float bowl looks like along with the screw: Here is a picture of a carb showing what is known as the overflow tube. It is the short tube which is open ended. Gas will flow from here when the float needle sticks in an open condition. The hose with the spring around it just below is the drain hose which is connected to the bottom of the carb bowl.
Post by xanthakita on Jun 18, 2012 4:19:09 GMT -6
ah ha! the drain hose is the one where the problem exists.. and I don't think there is a screw in that tube. where do I find a screw like that? Thank you. I'll let you know if that is the problem.
- UPDATE Checked it this morning and indeed that screw is gone... is it a special screw or will any screw that fits perform the needed function? Again, Thank you SO much!
Jonathan
Post by Cruiser on Jun 18, 2012 12:28:30 GMT -6
Your welcome, Jonathan. It is a special screw which goes with a tapered seat. Here is a source of these screws: www.partsforscooters.com/Welcome?search=carburetor+drainIn a pinch, you could remove the entire assembly from the end of the drain hose and just plug it securely with a screw or a golf tee until you get the replacement part.
