Post by beachbum on Aug 20, 2012 13:08:16 GMT -6
I have been trying to figure out if there is difference in SAE 90 and 85w-90. Besides the obvious difference in the numbers, is there a difference in the type of oil. My scoot calls for SAE 90.
Live To Ride / Ride To Live
Post by richardthescooter2 on Aug 20, 2012 13:27:20 GMT -6
I use a 80w90 on my 250cc scooter.
Post by Moat on Aug 20, 2012 21:31:36 GMT -6
SAE 90 and 85w-90 are essentially the same... the "85w" in "85w-90" just means that it's a multi-viscosity oil, and acts like an 85 weight oil at 32 degress F - the cold temperature rating that's denoted by the "w". At 212 degrees F (the hot temp rating), it acts just like a single-grade 90 weight oil. www.substech.com/dokuwiki/doku.php?id=gear_oils#viscosity_of_gear_oils Bob
Post by beachbum on Aug 20, 2012 21:43:06 GMT -6
SAE 90 and 85w-90 are essentially the same... the "85w" in "85w-90" just means that it's a multi-viscosity oil, and acts like an 85 weight oil at 32 degress F - the cold temperature rating that's denoted by the "w". At 100 degrees F (the hot temp rating), it acts just like a single-grade 90 weight oil. www.substech.com/dokuwiki/doku.php?id=gear_oils#viscosity_of_gear_oils Bob Hey, thanks. This was exactly what I was looking for.
