Post by slovenian on Aug 23, 2012 19:10:29 GMT -6
I'm so frustrated with this scooter! Every time i go to fix or adjust a thing, some crap always goes bad! I don't know is it just me, or my lack of knowledge or I'm just clumsy... (sure my English is bad)
The problem started when i tryed to put a different lamp into rear light. I put them in and started the bike, everything was OK, the bike started and the lamp was shining so i killed the engine, and took the keys out, and then went adjusting other lamp for the rear lights!
Yeah both were dead! I noticed that one lamp had 12v and 3W, and another had 12V 5W. So i thought its OK to put the "car type" lamp in... (they are just the same)
So i put the second lamp in ( now both were 12V 5W), and when i put the second I tryed to turn the key, and when i turned it I noticed that the voltage output is smaller (light on the dashboard and front light were very dim!!) so i took the key out and removed the lamps, when i was removing the lamp i saw i quite big spark at the lamp "connector" (where the lamp i goes in).
Next i tryed to turn the key and no feedback I got! Even the gas indicator didn't move! Clock is also dead!
So i checked the fuses next to the battery, and the were OK! I also changed them just to be sure! NO SUCCESS!
I tryed to refill the battery with a car charger. THE BATTERY IS FULL! still NO SUCCESS!
Is anything left to check??? another fuse box???
Can anyone explain to me what exactly is CDI, and can it be that my broke?
Where can i start to check to errors, and how can i solve my problem??
I'm offering a bear to anyone that helps me solve the problem (pay pal)
EDIT: after alot of reading, I think that main fuse could went bad.... how can i check it, and where to find the main fuse?? I was looking at the electrical diagram and i just dont get it... me and electrical stuff are strangers!
Any kind of assistance would be appriciated
Post by tvnacman on Aug 23, 2012 23:09:29 GMT -6
look under your seat .
Post by jaksonbrown on Aug 25, 2012 5:15:42 GMT -6
