Post by marvinlee on Aug 24, 2012 17:32:05 GMT -6
I got a 2008 lance duke 250 touring. Runs great no problems, except ; it's done this 3 times; it just dies, like someone pulled the plug, but always starts back up. Can any one help guide me to where to look for, I'm assuming a loose wire, or something? Any ideas would be great, Marvin.
Post by marvinlee on Aug 24, 2012 19:40:38 GMT -6
Also it just did it when I hit a bump, I think the bump helped. I'm sure it's a loose something. Looks like time to trace from battery; which is tight, and go from there.
Post by mike6736 on Aug 24, 2012 20:26:16 GMT -6
Yes check all your connections and also check the wires to the fan and sensor
Magoo
Post by marvinlee on Aug 24, 2012 21:19:13 GMT -6
Yep! That's the first thing tomorrow. I'll look for ground wires, everything on the right side of that bike, and the fan sensor area.
Post by marvinlee on Aug 25, 2012 15:51:08 GMT -6
Well I checked as best I could. I found that the main positive red wire was not tight, but not loose. I suspect just enough when you hit a bump or something it kicks off. It's tight now. This was the only area on the bike I had not invest aged to tighten things.
Post by marvinlee on Aug 26, 2012 17:19:13 GMT -6
Update. Well it did it again, but started. I quit using the Kill Switch to shut the bike off, and have not had it die yet. Yep, it's in there, those cheesy connections, I remember seeing when I padded the plastic windshield . If I'm really stranded I can get to it with a Phillips . Later.
