Post by millsc on Oct 26, 2012 22:25:31 GMT -6
i ordered a scrappys 52mm big bore kit gonna use an extra base gasket hopefully my timing chain will fit since its already tight after the hoca performance 50mm head will get a new stroker crank if it breaks my crank whats my chances of it lasting 3000 miles thats what id like to happen but if not ill get the stroker sooner or should i just change it now gonna do my gears tomorrow and get it tuned before i install the kit one thing at a time
Post by Alleyoop on Oct 26, 2012 22:48:00 GMT -6
If you can measure the height from the base to the top to see if it is taller than what you have on there you will know right away if the chain will fit or not. Alleyoop
Post by millsc on Oct 26, 2012 23:06:18 GMT -6
ill measure, hope it fits want to use the higher quality kit with my hoca head and do away with the cheap ebay piston and cylider was told the scrappy 52 kit is a malossi
