Senior Clinician
Post by millsc on Sept 14, 2013 6:49:28 GMT -6
i'll be in kansas city today shoot me a pm
Senior Clinician
Post by millsc on Sept 10, 2013 7:13:57 GMT -6
try a new cdi they go out all the time for no reason
Senior Clinician
Post by millsc on Sept 9, 2013 14:02:45 GMT -6
I have a 150cc ballastic i bought from scooterdepot it arrived in perfect shape and got the paperwork the same day the bike arrived, ive bought from many other online scooter dealers also shipping was slower at scooterdepot and i had a few minor issues with scoot early on but same with all the other scoots i bought online. I'd buy from scooterdepot again
Senior Clinician
Post by millsc on Sept 9, 2013 8:33:32 GMT -6
Senior Clinician
Post by millsc on Sept 7, 2013 14:03:08 GMT -6
Senior Clinician
Post by millsc on Sept 7, 2013 13:59:55 GMT -6
You can keep the airbox with 80cc 47mm kit, and run an 85-88 jet and stock pipe. The smaller kits work fine with stock airbox and stock pipe, the bigger 100cc 50mm kits work better with open airfilters. You will get better performance with an open airfilter on the 80cc kit with an 88 jet, the hipro pipe doesn't do much for the 47mm kits more or less just makes it louder. Use your stock head with the 80cc kit
Senior Clinician
tao tao 50
by: millsc - Apr 27, 2013 13:45:43 GMT -6
Post by millsc on Apr 27, 2013 13:45:43 GMT -6
Your a better man than me ;D
Senior Clinician
Post by millsc on Apr 8, 2013 7:39:46 GMT -6
I believe a scoot with a 39mm piston 49.5cc is dangerous you take a risk getting run over or ran off the road, my town is full of scoots so i bought one because it looked like fun. But once i got it cagers would tail me and honk and other stupid crap, so i began to mod and loved it. So now i do it as a job and for fun, my scoots aren't my main transport so i can take risks if it was my only transport i may have went with a smaller kit. Its not the size of the kit that kills the crank bearings and other stuff its the compression. A 80cc 47mm kit with stock head creates about the same amount of compression as the 100cc kit 50mm with the 50mm combustion chamber i've tested this, so either one will have around the same fail rate. So if you really want to be "safe" go with a 47mm kit with a matching 47mm combustion head.
Senior Clinician
Post by millsc on Apr 7, 2013 22:22:48 GMT -6
I agree my modded scoot runs like a champ got another scoot just to mod it since i couldn't mod my first one any more its maxed almost done with the second one, 2000 miles on the heavily modded 50cc with 52mm kit bigger than the op's 50mm kit no issues runs perfect starts right up every time
Senior Clinician
Post by millsc on Apr 7, 2013 21:21:22 GMT -6
install the kit correctly and keep up with the maintenance and ride it with a small amount of restraint and all will be good
Senior Clinician
Post by millsc on Mar 18, 2013 22:45:26 GMT -6
bad idea lol you never know some don't know, glad you do
Senior Clinician
Post by millsc on Mar 17, 2013 20:53:55 GMT -6
dont touch the glass of the headlight with your hand the oils from your hands will make it burn out in like a week
Senior Clinician
Post by millsc on Mar 15, 2013 11:36:08 GMT -6
there"s no clear way you have to pull it apart, what year and model i"ve took many apart, i may know.
Senior Clinician
Post by millsc on Mar 14, 2013 22:24:26 GMT -6
i did spray it down with water before i painted it today
Senior Clinician
Post by millsc on Mar 14, 2013 21:14:27 GMT -6
I put a new ignition in my roketa now the brake lights dont work everything else works and the wires match on the pin outs could the bulb be bad?
