Post by millsc on Oct 30, 2012 18:05:17 GMT -6
i installed my 52mm big bore kit went without a hitch runs great and smooth compression is 185 psi wot is that good?
Post by Bashan on Oct 30, 2012 18:49:27 GMT -6
That is great compression especially on new rings. You should be very satisfied with that and congrats on your good work.
Post by millsc on Oct 30, 2012 18:52:33 GMT -6
i used two base gaskets and a 50mm hoca head never checked compression before glad its in a good range thanks
Post by Alleyoop on Oct 30, 2012 19:53:55 GMT -6
You bet 180psi is excellent most are not that high. Alleyoop
Post by millsc on Oct 30, 2012 19:57:07 GMT -6
the electric starter fires it right up and im glad heard stories of people not being to use the electric start after installing a kit this size
