Post by Alleyoop on Jan 15, 2013 20:39:56 GMT -6
Great, I knew you missunderstood what I meant, that should help in keeping the bowl full when running at high rpms when less vacuum is produced. Alleyoop
Post by millsc on Jan 16, 2013 16:23:37 GMT -6
took the carb off again opened it up and realized the pin that holds the floats was pushed out pushed it back in and switched the hoses as you recommended and it runs as normal all fixed, i can bounce it all i want and not a studder
Post by Alleyoop on Jan 16, 2013 16:37:43 GMT -6
Great, easy fix but why did the pin come out I would question! Alleyoop
