Post by millsc on Feb 9, 2013 12:30:23 GMT -6
i checked my plug with the 100 jet with my 24mm carb, and it looked a little lean. So i put in the jet that came with the carb in it out of curiousity. Took it for a ride and before it ran 7500 rpms at full throttle which i thought was perfect, after the jet change the rpms windout to almost 9k and its faster, not sure why and maybe i need to keep that jet in there and up the weights, or should i leave it be?
Post by Alleyoop on Feb 9, 2013 13:35:55 GMT -6
If its a 4T put in heavier weights those are to high of rpms for a 4T, at those rpms it won't last very long the redline on 4ts starts at 8000k. You want to run like before around mid 7Ks or little lower at WOT. If its a 2T then it is a different story they make their power at high rpms. Alleyoop
Post by millsc on Feb 9, 2013 13:49:22 GMT -6
wonder why it changed after the jet switch?
Post by Alleyoop on Feb 9, 2013 13:51:53 GMT -6
Do you know what size the one you switched is? If it was a 24mm carb they usually come with a main jet anywhere from 103-107 so your 100 was lean. Alleyoop
Post by millsc on Feb 9, 2013 13:52:50 GMT -6
I have no idea what jet it is, it was unmarked, was running a 100 main jet before.
Post by Alleyoop on Feb 9, 2013 13:53:55 GMT -6
So like I said your 100 was Lean. Alleyoop
Post by millsc on Feb 9, 2013 13:56:23 GMT -6
ok i have some 10 gram weights, i'll put those in to stay under the redline
Post by millsc on Feb 9, 2013 18:49:06 GMT -6
i settled in a 9.5 grams i was running 9.5 and 9 gram mixed and after jet change i went over 8k at wot put the 9.5 set in and it maxes around 7.6k rpms i'm comfortable with that, even though it was slightly faster at over 8k.
Post by Alleyoop on Feb 9, 2013 18:52:46 GMT -6
That sounds good mills right on the powerband of the 4ts. Alleyoop
