Post by lacrosseguy on May 14, 2013 19:07:47 GMT -6
Post by Alleyoop on May 14, 2013 21:29:29 GMT -6
I would get a new jug and piston the way the piston is marked up the jug is also scored and will happen again if you just put a piston in it. Alleyoop
Vespa Specialist
Post by Kaveman on May 14, 2013 21:59:41 GMT -6
I agree with Alley. Best to replace both sooner than later .Otherwise its just more $$$ out of the pocket if you don't . willc.
Post by lacrosseguy on May 14, 2013 22:15:21 GMT -6
is a jug a cylinder ? sorry im a n00b if i get a 80cc BBK(The one from ScrappyDog), will i have any problems installing ??
would this piston cause troubles with starting?
Post by Alleyoop on May 14, 2013 22:25:00 GMT -6
Yes the jug is the cylinder that the piston rides up and down in.
If it produces enough compression it should start. But the question is what caused it to score like that, did you check the rings on it are they all in tack. if all is in tack then I think it was running really LEAN and it expanded and almost seized. Alleyoop
Post by lacrosseguy on May 14, 2013 22:31:59 GMT -6
yeah, im thinking the last owner ran really lean and put regular gas in it.
Ordering my BBK in the morning. Thank you so much Alleyoop, I appreciate your advise and information so much.
