Post by ctpgs on Jun 16, 2013 13:41:25 GMT -6
hi new here, i have had a problem getting scooter to start, can get it to start once in awhile but it will just die,went and cleaned the carb, new spark plug checked to make sure i had spark and i do,checked fuel and vacuum lines , air filter and still nothing, cranked with the electric start until battery died, i went to charge the battery and noticed the positive side was very rusted not corrosion but rust, also after charging the battery it cranked but when i went to try again the battery didn't even crank, just nothing no break light no display on digital dash not sure where to go from here, any advice would be great, it did start and run last time i rode it and it is a 2 cycle
Post by Deleted on Jun 17, 2013 13:38:37 GMT -6
Check your fuses with a test light or meter. The rust would be the battery terminal bolt. You should replace it to get a good connection from battery to the rest of the system.
Check your fuel filter and test your petcock. Is the gas fresh?
Post by Bashan on Jun 18, 2013 15:54:56 GMT -6
Yep, great advice, you should check everything DW went over. Also, 2Ts are infamous for reed valve problems. If you can give us the make and model of your bike I'll see if I can dredge up a manual to go by for this. Also, I''ll see if I can get Shalom72c to look at this thread. He has a 2T Stella and is well versed in their repair.
Vespa Specialist
Post by Kaveman on Jun 18, 2013 17:14:14 GMT -6
The scoot is not a Stella 2T correct ? will c.
Post by ctpgs on Jun 18, 2013 19:15:51 GMT -6
it is a keeway f-act 2009 had blown fuse so that fixed cranking issue, still no start killswitch is in right position fuel line is new, plenty of fuel pouring out of line when vacuum applied, around 1500 miles on engine, checked spark grounded engine and had bright spark, tried putting thumb over hole but am going to borrow compression tester, with thumb over and cranking air blows right past, took carburetor off and completely cleaned with carb cleaner and compressed air, removed jets and soaked them and blew out with compressed air still nothing
Post by Deleted on Jun 18, 2013 19:37:50 GMT -6
Is the air filter clean?
Post by ctpgs on Jun 18, 2013 20:26:48 GMT -6
air filter is clean
Post by Deleted on Jun 19, 2013 1:04:48 GMT -6
Is your spark plug wet with gas after cranking? If not check your float valve and run a thin wire up through the jets to clean them good.
Any way you can easily check the exhaust port for carbon buildup? Happened to me once on a 2stroke.
When you checked for spark, did you ground the plug to the engine or frame?
How are those reed valves?
Post by ctpgs on Jun 20, 2013 7:59:22 GMT -6
spark plug is wet with gas, exhaust is only 6 months old, and reed valves look new
Post by Deleted on Jun 20, 2013 13:31:48 GMT -6
Spark plug could be leaking while installed. Check the ground between the engine and frame. Try a compression gauge.
