Post by Steve on Jun 23, 2013 18:24:02 GMT -6
Beats me!!!! On my Romans 150cc I have a small two wire connector on the right-hand side under the floorboard. Please see the pics. Any idea what it is for??? I finally realized what the eight wire connection was for that was under the seat in the middle of the scooter. (Pic included) It was for the alarm. Of course I found that out AFTER I spent hours on the web searching for how to wire the alarm. I be learnin' a lot, thanks to you guys! Appreciate any info you can send my way. < Steve >
Post by Alleyoop on Jun 23, 2013 18:35:14 GMT -6
just about all harness have extra connectors for options that may not be on that scoot. I have some connectors that do not connect to anything as well.
If something is not working check the wires coming from it and see if it is connected and if not then it you look for a matching plug that is hanging. But it could just be a spare plug for something your scoot does not have. Alleyoop
Post by Steve on Jun 23, 2013 21:46:20 GMT -6
Yeah. I thought that 8-wire connector was for a diagnostic machine or ?? When I trying to install an alarm, I noticed that the connectors looked similar. Viola!
So...I figure the 2-wire connector has to be for an additional --- that I don't have.
Thanks!
Post by Deleted on Jun 24, 2013 1:13:14 GMT -6
If the 2 wire gives ya 12Vdc that switches off with the key, it's most likely an accessory port. For tunes or lights and such.
Post by Bashan on Jun 24, 2013 4:53:51 GMT -6
Steve, I don't know what's going on with Proboards in regards to attachments. Some of them work and some do not. The one you posted comes back as failure codes, at least it does for me. Check your PMs, I gave you a couple options.
Post by Steve on Jun 24, 2013 23:43:03 GMT -6
Just trying to see if the PDF is the problem and JPGs get thru fine... Give it a try.
I was able to open the PDF I attached. No problem.
Maybe we can figure it out.
< S >
