Post by cdmor on Jul 19, 2013 22:04:10 GMT -6
Over the past few months my headlight (even bright light indicator) has dimmed occasionally and then returned to normal. During the moments when it dims, RPMs have no effect. No other electrical gages or lights are affected. Now it seems to be permanent. Headlight is so dim, I can no longer ride at night. I keep bike connected to maintainer when not in use and have new battery less than a month old. Bike starts and runs fine, just extremely dim headlight. Hope someone can help or know of possible solution as local scoot shop has 2 week out waiting list.
Post by Alleyoop on Jul 19, 2013 22:11:52 GMT -6
Get a volt meter and connect it to the battery and rev it up to 3-4k and see what it reads. The Regulator/Rectifier may be bad. Alleyoop
Post by cdmor on Jul 19, 2013 22:36:09 GMT -6
Thanks for your reply. Not familiar with a voltage meter. DC at battery right? What should it read?
Post by Alleyoop on Jul 19, 2013 23:00:19 GMT -6
Post by cdmor on Jul 20, 2013 18:47:29 GMT -6
Replaced regulator today and no change to head light. Hope someone can give any idea of to try next. Had stator replaced about 6 months ago.
Post by Alleyoop on Jul 20, 2013 21:41:17 GMT -6
If your going to own any kind of a scooter or motorcycle you need a VOLT METER and a LIGHT TESTER. You need to find out if your battery has a bad cell and how your charging system is working. Otherwise your going to just be replacing parts and wasting money. Alleyoop
Post by dragonsparks on Jul 21, 2013 1:34:30 GMT -6
I totally agree with Alley you're going to need a decent multi-meter. Just make sure it test for continuity. A light tester is useful to. I have one made by snap-on & I haven't used it in 20 year's. That's only because I don't do low voltage motor controls & energy management control systems any longer. I personally prefer my amp probe multi-meter. That's just me.
If I remember right if you test your battery at rest with a full charge anything from 13.2 to 13.8 is great. 12.6 to 12.9 average. 12.0 to 12.4 is bad.
Dave
