Post by turboblue on Aug 18, 2013 16:04:03 GMT -6
When I am going around 20mph or so it sometimes seems like a fuel is not getting to the carb. It does keep running but just seems to be some type of power loss.
Post by mike6736 on Aug 18, 2013 19:40:05 GMT -6
I know you said you set the valves earler but are you sure you have them right?
Magoo
Post by Alleyoop on Aug 18, 2013 21:28:32 GMT -6
Turbo, Need a little more detail explaination on how it acts, does the motor make a BOGGGGGGGGG sound or make any different sound than normal?
If your going 20mph and twist the throttle what happens? Does it hesistate or stumble then recover or what. Alleyoop
Post by turboblue on Aug 19, 2013 19:11:20 GMT -6
I will recheck the valves. Pretty sure I have it right. The bike did not do it much this time around. I did pull out some gunk in the fuel line before I ran it. I know the gas tank is nasty but I want to run some more gas out first before cleaning it. I tightened some clamps on the lines that seemed to help. As for the noise it does not have a huge noise. Just not speeding fast enough then it kinda gets gas and then takes off. One time it did stall out but then fired right up. Thanks for all your help.
