brake light.
by: gy6139qmb2013 - Sept 5, 2013 16:44:51 GMT -6
Post by gy6139qmb2013 on Sept 5, 2013 16:44:51 GMT -6
So my 50cc schwinn gy6 has had all the plastic taken off. only the seat and floor board are existent. So I have many wires hanging out. And Im more concerned about the rear brake light working than anything. i do have a few plugs/harnesses towards the rear by the fuel tank. Two of them are just 2 wire plugs/connectors and the third has 3 wires. Im not sure but I cant get a light to light up when I use these plugs. Also My battery is dead? But Im thinking the rear brake light would still function while motor is running? also Im not sure how its activated switch wise? Thanks.....
Post by Deleted on Sept 5, 2013 16:54:16 GMT -6
theres a switch on the brake levers usually. the 3 wire connection should be your brake/tail light harness.
Post by Alleyoop on Sept 5, 2013 16:59:53 GMT -6
Your brake lights work off the battery, so you have to get a new battery. That is why when you go to start it you turn on the key SQUEEZE the Brake and the stop lights come on then the motor starts. Alleyoop
brake light.
by: gy6139qmb2013 - Sept 5, 2013 18:31:57 GMT -6
Post by gy6139qmb2013 on Sept 5, 2013 18:31:57 GMT -6
theres a switch on the brake levers usually. the 3 wire connection should be your brake/tail light harness. Nice...Ty
brake light.
by: gy6139qmb2013 - Sept 5, 2013 18:33:06 GMT -6
Post by gy6139qmb2013 on Sept 5, 2013 18:33:06 GMT -6
Your brake lights work off the battery, so you have to get a new battery. That is why when you go to start it you turn on the key SQUEEZE the Brake and the stop lights come on then the motor starts. Alleyoop ok....Ty
