Post by The3rdLevel on Sept 8, 2013 15:15:04 GMT -6
I've done the 11 pole Stator/7 Wire Regulator mod. I'm running the stock headlamp but on dc using a relay that is triggered of the white wire on the R/R. I have also changed the flasher relay with an electronic relay(to avoid having to use a load resistor in conjunction with an all LED setup) My only deviation is I am keeping the headlamp relay near the R/R and CDI. I have noted my deviation from the directions found on this site. ![](http://i1301.photobucket.com/albums/ag115/the3rdlevel/7Wire3yellowRegBNG_zps6679a4f7.jpg) When I run the bike now my and turn my hazards on at idle they flash normal speed. When revving past idle the flash rate speeds up. After a bit the main fuse(10 amp) blows. I've tried measuring voltage with my digital meter at the battery and get normal readings with the bike off, but once I start it my display changes voltages rapidly up and down. I'm stuck here and dont know what to check next.
Post by Alleyoop on Sept 8, 2013 15:58:10 GMT -6
Rich I am sure will chime in, he is the Electrical Guru. Alleyoop
Post by tvnacman on Sept 8, 2013 17:39:13 GMT -6
can t a picture of your meter ? Please tell us what setting you are reading the voltage in .
Post by The3rdLevel on Sept 9, 2013 7:12:40 GMT -6
I've tried using DC20V and DC200V ranges on the meter
