Post by bobthetechguy on Sept 25, 2013 17:08:40 GMT -6
So I am now the proud owner of a second hand 2010 peace sports 50. Its OK, except for not doing more than 25mph unless I'm headed down hill. I was wondering what's the easiest way to unrestrict it so I could get just a tad more power from it Attachments:
Post by Alleyoop on Sept 25, 2013 18:01:47 GMT -6
Check your Variator it may have a washer to stop the Variator from closing so the belt does not climb high to keep the speeds down. Also the carb could also be restricted, some come with a limiter so the DIAPHRAGM cannot rise enough to pull the needle all the way out for more gas, as well as the Header pipe they insert a piece of pipe smaller to restrict the motor from breathing and getting rid of the exhaust. Another one could be a restricted CDI which limits the RPMS the motor will rev up to. Alleyoop Here are some how to and what you might find it all depends on the type of scoot but this will give you an idea of what it may be restricted by. www.scootnfast.com/scooter/Tuning_mods/De-Restricting.htm
Post by bobthetechguy on Sept 25, 2013 23:33:44 GMT -6
That 3 wheeled scooter in your Sig looks freaking awesome to drive
Post by Alleyoop on Sept 25, 2013 23:40:14 GMT -6
That WAS a150cc 149.6 motor, it is modded to the hilt. It will smoke most 250s(HAHA) and definitely the 300cc Trikes. Here is how I have it currently set up: Alleyoop
Here is what my PST150H Ice Bear Trike currently has it was a 149.6cc Motor now it is 182cc motor: 62mm BBK 60mm Stroker Crank 16/37 Hoca Tranny Gears – Original were 13/40 - I have 18/36 gears that I have not tried yet K&N Air Filter with a Short Stack SuperTrapp Muffler 1 1/4 Header Pipe- Had it made 24mm Carb #122.5 Main Jet #38 Pilot Jet Peformance Coil/CDI- Cdi is one that is retarded at low rpms but advances at 3000 rpms, my motor has so much compression it kicksback with any other fixed advanced performance Cdis. Manual Choke Iridium Plug Prodigy Variator 12g Dr. Pulley Sliders 205/65-10 Kenda Load Tires-3"s taller than OEM 29 tooth Drive Sprocket-came with 24 tooth. DID 428 Pro V Series O-Ring Chain Givia 29" tall Windshield All Led bulbs Except the Headlights-I do not drive at night 4 way Flasher Turn Signal Beeper Relay for the Beeper connected to the Brakes VIP Trunk with Led lights Radio with SD card,MP3 connections
Post by bobthetechguy on Sept 26, 2013 0:35:31 GMT -6
How's the cornering like on that?
Post by sumdawgtwigg on Sept 26, 2013 1:39:54 GMT -6
Enjoy your new scooter!
Post by bobthetechguy on Sept 26, 2013 10:23:50 GMT -6
Where is the air/fuel mixture screw on this carb? its running about a 1/2 turn too rich.
Post by bobthetechguy on Sept 26, 2013 10:25:54 GMT -6
