Oil Leak
by: darla - Nov 16, 2013 9:24:43 GMT -6
Post by darla on Nov 16, 2013 9:24:43 GMT -6
Jonway 150cc and I've noticed a pretty significant oil leak. Can't tell exactly where it's coming from. It runs fine, but when I park it I can see a lot of oil within minutes.
Oil Leak
by: kz1000st - Nov 16, 2013 9:40:55 GMT -6
Post by kz1000st on Nov 16, 2013 9:40:55 GMT -6
It's either the head gasket, valve cover gasket or cylinder base gasket.
Oil Leak
by: jct842 - Nov 16, 2013 12:29:35 GMT -6
Post by jct842 on Nov 16, 2013 12:29:35 GMT -6
Take the plastic side panels off and clean it good. Then start it on the centerstand so you can monitor where it is coming from. When you locate the source report back in and some one will be able to tell you the next step. If it is a lot of oil I would be careful about riding it as the engine does not have much oil in reserve and can run out easily.
Oil Leak
by: Alleyoop - Nov 16, 2013 13:15:54 GMT -6
Post by Alleyoop on Nov 16, 2013 13:15:54 GMT -6
If it is coming from the Right side by the Fan is most likely the crank oil seal on that side. If it is dripping from the front of the motor most likely the valve cover is leaking. If it is dripping by the CVT and you have an air box it is from the VALVE cover vent hose and the filter is clogged with oil and not letting it breath.
So tell us where about the oil is dripping from under the motor. Alleyoop
Oil Leak
by: bobthetechguy - Nov 18, 2013 17:57:25 GMT -6
Post by bobthetechguy on Nov 18, 2013 17:57:25 GMT -6
Mine is leaking pretty bad too. Looks like killed 2,birds with 1 stone in this thread.
Oil Leak
by: john357 - Nov 26, 2013 20:02:57 GMT -6
Post by john357 on Nov 26, 2013 20:02:57 GMT -6
I have a 2013 Roketa 150cc and it is leaking a lot of oil from underneath the left aluminum panel. I've only had the bike for three weeks and have only driven it 30 city miles, not hard miles. What can be causing this major oil leak and how can I fix it? Thanks for the input.
Oil Leak
by: Alleyoop - Nov 26, 2013 20:38:20 GMT -6
Post by Alleyoop on Nov 26, 2013 20:38:20 GMT -6
I have a 2013 Roketa 150cc and it is leaking a lot of oil from underneath the left aluminum panel. I've only had the bike for three weeks and have only driven it 30 city miles, not hard miles. What can be causing this major oil leak and how can I fix it? Thanks for the input. Left aluminum panel I take it you mean the CVT cover. If so it is most likely the Crank Oil seal. alleyoop
