Post by Bashan on Jun 6, 2010 13:24:38 GMT -6
I remember someone asking me a question about this sometime ago and I just stumbled across if for any one that's interested. MAGNETIC OIL DRAIN PLUG
2010 SUNL 150cc
Post by trixrabite on Jun 6, 2010 14:10:13 GMT -6
I believe the bolts from the looks of it... are possibly different gearbox drain plugs possibly?
Post by Cruiser on Jun 6, 2010 19:17:33 GMT -6
Post by Alleyoop on Jun 6, 2010 19:31:00 GMT -6
Well I ordered the Magnet Plug kit as well so we shall see how it works. Now here is the thing the shipping is $7.43 and then he has the NERVE to charge $1.00 for Handling Alleyoop
Post by zugzug on Jun 6, 2010 20:04:04 GMT -6
C'mon you guys dont know what they are for? You sure you changed the oil on your scoot before? The big one is for where the oil screen is on the right side of the scoot motor, the medium one is for the oil drain on the left side of the motor, and the small one is for the gear oil which is left side at the rear of the CVT. The washer is for the oil drain bolt. -Zug
Post by Alleyoop on Jun 6, 2010 22:06:00 GMT -6
I know what each is for I am just curious how well they will work Alleyoop
2009 83cc Road Runner
Post by cyberbeer65 on Jun 8, 2010 14:29:54 GMT -6
I wonder if that would fit my scooter?
Post by thecableguy on Jun 9, 2010 7:36:27 GMT -6
Ok, so is the cap for the screen magnetized too? So could I put the magnetic drain bolt in one scoot and the magnetic "filter cover" on the other? Then the scoots could fight over the gear bolt...
Post by Alleyoop on Jun 9, 2010 9:11:51 GMT -6
There you go, let them make the decision Cableguy, by the way thanks for the Beeper Signal with a Twist, I already had a Beeper so I just had to add the Relay, WORKS GREAT Alleyoop
Post by thecableguy on Jun 9, 2010 9:36:59 GMT -6
Glad to help... Let me know when you get the magnetic plugs in if it looks like that filter cover is magnetized too...
Jim
P.S. I think the JMStar would get it, she's got a bit of gear whine the Roketa doesn't.
Post by Alleyoop on Jun 9, 2010 10:35:46 GMT -6
Cableguy, Yes the Filter Screw has a magnet in the center. Alleyoop
Post by thecableguy on Jun 9, 2010 20:00:14 GMT -6
Ok, I might have to order some of those then...
Thanks!
Post by speedracer on Jun 9, 2010 20:27:41 GMT -6
OK, so the spring and screen are no longer used?
Post by thecableguy on Jun 9, 2010 21:30:44 GMT -6
No, you still use your existing spring and screen...
Post by speedracer on Jun 10, 2010 8:29:06 GMT -6
Thanks thecableguy, wasn't sure if they were still needed or of any use.
