Post by jamiec1991 on Dec 11, 2013 16:04:42 GMT -6
my headlights wont work on my bike after i have put a brand new wiring loom on it, brand new clocks, brand new switch gears brand new regulator, its the full beam and dipped beam thats wont work all the other lights work on the bike i look over the connections a number of times i checked the output of the stator thats fine i checked the bulbs with jump wires to my battery and they light up, i checked the fuse. i be greatful if anyone could help me please ;D
Post by rob63 on Dec 11, 2013 16:14:09 GMT -6
Does the engine on your bike need to run to make the lights work ? Trace the wire which feeds your dip or hi beam up to the hi/lo switch. On that switch will be 3 wires, one each to feed the hi and lo beams, the other will be a feed from your on/off light switch. Check the feed on that wire at the hi/lo switch, if there is voltage then the switch could be faulty. If there is no voltage then you need to trace the wire back to the on/off switch. Here you will find another 3 wires, one to feed the side light, one to feed the hi/lo switch, the other will be a feed from your stator or battery depending whether it`s an AC (lights work only with engine running) or DC system (fed from battery). Check that this wire has voltage.
