Post by sabotendar on Apr 9, 2014 12:45:52 GMT -6
Yes, your turn the IDLE SPEED SCREW so that your REAR WHEEL JUST WANTS TO TURN. The other screw you adjust it FIRST the last thing to adjust is the IDLE SPEED SCREW: To adjust the other screw FIRST START it up and let it run for about 5 minutes to let it warm up. 1. Turn the Mixture Screw 1/4 COUNTER CLOCKWISE. a. IF THE IDLE GOES UP REPEAT #1 UNTIL THE IDLE DOES NOT GO UP then go SET YOUR IDLE #3. b. IF on the FIRST 1/4 TURN the IDLE DOES NOTHING or GOES DOWN go to #2 2. Turn the Mixture Screw 1/4 CLOCKWISE. a. IF THE IDLE GOES UP REPEAT #2 UNTIL THE IDLE DOES NOT GO UP then go SET YOUR IDLE #3. SET YOUR IDLE: 3. Set the idle so that the REAR WHEEL JUST WANTS TO TURN. The oil mix with the gas IT SHOULD SMOKE SOME if it does not smoke you need a little more oil. The Needle I would set it in the middle slot. That adjustment is if the motor needs more or less fuel in the MID RANGE. Alleyoop Now i know what i doing wrong i adjust the IDLE screw until the REAR WHEEL turn so when she turn i rotate counter-clockwise till she stop to turn A tachometer would make a difference now! on the manual says to adjust until 1750 to 1800RPM where is the tachometer? About smoke i think smokelees is good it have to make some smoke correct? so my mixture have poor oil combination i will raise the mix now...The fuel tank have 5L how much oil(milliliters) i have to put for a full tank? The sportive air filter can be a bad factor too? I like to put the original again but i dont now what is inside because when i open dont have nothing inside, i can put a piece of foam inside it? If so that's all I put in there? Thanks for the guys help me on this journey. Sabo.
Post by Alleyoop on Apr 9, 2014 13:13:24 GMT -6
Post by sabotendar on Apr 9, 2014 13:46:33 GMT -6
I now know the exact mix. Very nice Tach! And about he air filter? any problem if i keep the sportive one or i have to put oldone on place what is inside of old air filter? Sabo.
Post by Alleyoop on Apr 9, 2014 14:06:59 GMT -6
If it runs good with the one on there LEAVE IT ALONE(HAHA). Otherwise you will have problems with fuel and air ratio JUST LIKE THE OIL Alleyoop
Post by sabotendar on Apr 9, 2014 14:12:39 GMT -6
If it runs good with the one on there LEAVE IT ALONE(HAHA). Otherwise you will have problems with fuel and air ratio JUST LIKE THE OIL Alleyoop For me works very nice! But here in Brazil they say that this filter makes the bike consume more fuel this is truth? Sabo.
Post by Alleyoop on Apr 9, 2014 14:23:56 GMT -6
A motor has to take in so much air and fuel to work right. It all Depends on the Air Filter IF it lets a lot of air in then you need more fuel to match the amount of air. Less Air less gas etc..
So if you put on a FREE FLOW AIR FILTER(lets a lot of air in), you will need to adjust the carb to feed it more fuel, and you may need to put in a bigger main jet. Alleyoop
Post by sabotendar on Apr 9, 2014 15:10:15 GMT -6
A motor has to take in so much air and fuel to work right. It all Depends on the Air Filter IF it lets a lot of air in then you need more fuel to match the amount of air. Less Air less gas etc.. So if you put on a FREE FLOW AIR FILTER(lets a lot of air in), you will need to adjust the carb to feed it more fuel, and you may need to put in a bigger main jet. Alleyoop So the best choise for me is to put the old one back but what is inside of the box? i see in the manual it have a foam inside but it have to be oiled with what oil? On the manual only says "special hyosung oil" I look for what is inside of the box here on local bikes shopping and BELEAVE ME! no one knows what goes inside very good traders Sabo.
Post by Alleyoop on Apr 9, 2014 15:22:46 GMT -6
Post by sabotendar on Apr 10, 2014 4:34:06 GMT -6
Today i will try setup the carb like Alley said. On the last days i come to home very exaust to tray to do something on the bike the only thing i do was to raise the mix of oil now i have a little smoke After i make the config i will post the results. Sabo.
Post by sabotendar on Apr 11, 2014 6:14:52 GMT -6
Hello guys i have a little update for you, i find a very cool app for android cell phones to calculate the correct mix of gas/oil for 2 stroke motors the name is "2 stroke Mixture" now i can calculate in my phone without have a internet and PC. Hey i almost forget i can store the mix on a 5L gallon in my home? So when fuel is running low I can fill the tank of the bike at home, any problem or recomendations?
Sabo.
Post by Alleyoop on Apr 11, 2014 14:03:10 GMT -6
Yea, keep the gas in a cool place. Also the Wiring for the CDI it looks like it can be converted over to a regular common CDI but you will have to rewire it. Now the IMPORTANT thing is to FIND OUT WHERE THE WIRES that PLUG INTO THE CDI are coming from to be able to draw up where the WIRES would go on a COMMON CDI. Alleyoop
Post by sabotendar on Apr 11, 2014 14:56:58 GMT -6
Yea, keep the gas in a cool place. Also the Wiring for the CDI it looks like it can be converted over to a regular common CDI but you will have to rewire it. Now the IMPORTANT thing is to FIND OUT WHERE THE WIRES that PLUG INTO THE CDI are coming from to be able to draw up where the WIRES would go on a COMMON CDI. Alleyoop Hey this is good thing and here another one i find a guy here in Brazil and he have almost all parts from this bike im chat whit him to see what parts he have. I will post the news soon. Sabo.
Post by Alleyoop on Apr 11, 2014 15:08:18 GMT -6
GREAT!! Get all the parts NOW(HEHE). Alleyoop
Post by Bashan on Apr 11, 2014 22:06:31 GMT -6
Sabo.....you never call......did I do something wrong?
Post by sabotendar on Apr 12, 2014 9:54:20 GMT -6
Sabo.....you never call......did I do something wrong? No im here! im always here, but im working at moment, hey heres the news i came to work on the bike today and, although, the carb still be deregulated she walked very well on straight lanes tomorow i will regulate this guy. Hey i make the mix of oil/gas and i see smoke only when in idle but when i throtle i see some smoking but after a time she desapears and return only if a put in idle and pull the throtle again, it is normal? Call anytime my friend. Sabo.
