Post by sabotendar on Apr 12, 2014 16:59:59 GMT -6
Guys i setup the carb and by my tests the bike still works the config told by Alley save me now in idle speed the bike still works tomorow i will place the old filter on place and i know i have to config the carb again.
Sabo.
Post by Alleyoop on Apr 12, 2014 17:09:23 GMT -6
Sabo.....you never call......did I do something wrong? No im here! im always here, but im working at moment, hey heres the news i came to work on the bike today and, although, the carb still be deregulated she walked very well on straight lanes tomorow i will regulate this guy. Hey i make the mix of oil/gas and i see smoke only when in idle but when i throtle i see some smoking but after a time she desapears and return only if a put in idle and pull the throtle again, it is normal? Call anytime my friend. Sabo. That is because you have the throttle wide open and a lot of gas is coming in. So you need a little more OIL to gas mixture. Maybe add more 1 oz of oil to the mixture and see if it smokes at wide open throttle. If it still does not smoke add another 1 oz etc.. Alleyoop
Post by sabotendar on Apr 12, 2014 17:52:59 GMT -6
No im here! im always here, but im working at moment, hey heres the news i came to work on the bike today and, although, the carb still be deregulated she walked very well on straight lanes tomorow i will regulate this guy. Hey i make the mix of oil/gas and i see smoke only when in idle but when i throtle i see some smoking but after a time she desapears and return only if a put in idle and pull the throtle again, it is normal? Call anytime my friend. Sabo. That is because you have the throttle wide open and a lot of gas is coming in. So you need a little more OIL to gas mixture. Maybe add more 1 oz of oil to the mixture and see if it smokes at wide open throttle. If it still does not smoke add another 1 oz etc.. Alleyoop I make this and works. I make the mix out from fuel tank on a 5L gallon and empted fuel tank and place the mixture from gallon on fuel tank 125ml oil on 5L gas now is perfect smoke on mufler. Sabo.
Post by Alleyoop on Apr 12, 2014 18:52:39 GMT -6
Good, make sure it smokes otherwise the MOTOR WILL SEIZE that is what LUBRICATES it and keeps it from getting red hot. Alleyoop
Post by Bashan on Apr 12, 2014 20:18:25 GMT -6
I was kidding Sabo.....you're a sweet guy...and that's a good thing in this country. It means you're nice and care about other people.....even boneheads like me. We Yankees can't be serious for more than two minutes at a time. I'm sorry man, I was just joking. I'd call your arse if you could understand anything I say with my cross between a northern and southern accent, and if the bill wasn't $10,000.00 to Brazil! I don't know...maybe you'd be worth it. HA! See? Joking around again! Rich
Post by sabotendar on Apr 13, 2014 8:18:27 GMT -6
I was kidding Sabo.....you're a sweet guy...and that's a good thing in this country. It means you're nice and care about other people.....even boneheads like me. We Yankees can't be serious for more than two minutes at a time. I'm sorry man, I was just joking. I'd call your arse if you could understand anything I say with my cross between a northern and southern accent, and if the bill wasn't $10,000.00 to Brazil! I don't know...maybe you'd be worth it. HA! See? Joking around again! Rich Hey no problem i will stay here for many times i have many to learn with you guys i start to like of motors and his funcionalities i will never be a mecanic but know how it work is very good if a planed have a better bike on future, fix this bike for my wife is very good for me i enjoy the knowledge, i am joke man to in most parts of time, this make the life better. But lets change the chat a little :-) Today here is my time to make the lunch for my wife so lets eat some fish with potatos...until the next time guys. Sabo.
Post by sabotendar on Apr 13, 2014 11:53:40 GMT -6
I setup the carb now in idle she dont stop, but i have bad news too she lost performance since before i regulate the carb, a descarbonization is the solution? After i fix she run well and before the fix too but about 3 days later she lost its performance what did you think? How to procede to make a good descarbonization?
Sabo.
Post by Bashan on Apr 13, 2014 19:37:03 GMT -6
Did you check the plug? Sounds like too much oil in the gas. How did you determine the mixture? Rich
Post by sabotendar on Apr 14, 2014 3:54:22 GMT -6
Did you check the plug? Sounds like too much oil in the gas. How did you determine the mixture? Rich Spark plug? Is ok! About the mix i make 40:1 (125ml oil for 5L gas) white smoke on mufler many smoke, i dont know if it counts but with less smoke the bike works beter but maybe is many carbon on cilinder,piston and rings, this is correct? Sabo.
Post by sabotendar on Apr 14, 2014 15:27:46 GMT -6
Hey guys here are you?
Post by Alleyoop on Apr 14, 2014 15:37:35 GMT -6
Yes the motor will run better with LESS oil, to much oil will produce to much smoke and will lower the power. I would test the mixture you may need. Get a half gallon of gas and bring down the mixture it may be that 40:1 is to much oil so try 35:1 or something in between. All you want is that some smoke is coming out YOU DO NOT want to blind someone behind you with the smoke(HAHA) Alleyoop
Post by Bashan on Apr 14, 2014 21:39:25 GMT -6
I think 40 to 1 is a lot, what does the manual say or is it just concerned with automatic mixing via bike systems? Rich
Post by Bashan on Apr 14, 2014 21:54:59 GMT -6
This engine is more complicated than a simple outboard. Here's what the manual says about the oil delivery. It's variable. I just don't think premixing will get it with this bike. JMO but I'm not good with two strokes. Rich
Post by Deleted on Apr 14, 2014 21:58:30 GMT -6
premixing isnt going to hurt so long as you block off the oil pump properly. theres not much difference between this and your weedeater engine.
Post by Bashan on Apr 14, 2014 22:01:45 GMT -6
premixing isnt going to hurt so long as you block off the oil pump properly. How do you do that oh great illumination man? Rich
