Post by jpp on Aug 4, 2014 13:51:56 GMT -6
the new batteries i got is the xtreme agm 12 v - 6 ah the part no is xtax7a-bs
the one that came with the scoot new was 12 v - 7ah
the new one says it replaces the old one.
Post by jpp on Aug 4, 2014 12:53:27 GMT -6
Bashan Thank you I did not know about the different threads, I tried to start one on trikes just now and got the message that i could not start one ?? Jeff
Post by jpp on Aug 4, 2014 10:48:35 GMT -6
Hello, I own a Ice Bear 50 cc trike, it has been running fine after replacing the carb, cdi and coil about 6 months ago. The batteries was shot so i've been using the kick start the last few months, The k/s gear now stipped so i bought a new batteries this weekend the scooter stated fine i shut it down then restated everything was good, sounded like it was warming up as always then it started losing power ( would give it gas and nothing ) then just died next time took several trys to get it stated and again same thing. then nothing at all it cranks but will not start. I replaced the plug this afternoon and still nothing could it be a electrical coil, cdi or auto chock? have made no adjustments to carb at all have not checked fuse yet, but if were bad would it still crank ?lights work all of them horn barely works. any ideas please help jeff Read more: scooterdoc.proboards.com/thread/10580/50-cc-ice-bear-start#ixzz39RVo1fEU
Post by jpp on Aug 4, 2014 10:33:47 GMT -6
can,t do anything now, battery dead. charging now I have never adjusted the valves... until this occurrence the scoot ran fine.I will update after battery is charged and it stops raining. Jeff
Post by jpp on Aug 3, 2014 20:32:16 GMT -6
jeff
