Post by hobbles on Nov 8, 2016 9:52:56 GMT -6
Never mind, I got it. I'm not sure what this part is called, but I reversed the big hoses and it works fine now. Some times I even impress myself..... ![8D](//storage.proboards.com/3059616/images/bG1D3NlbiR447pUgxo24.gif) ![](http://img.photobucket.com/albums/v323/hobbles/Judy/Trike/vent%20part.jpg)
Post by hobbles on Nov 8, 2016 9:15:50 GMT -6
Not sure if this means anything, but when I add oil, it takes a long time for the trike to accept it. Almost like it need an air vent.
Post by hobbles on Nov 8, 2016 8:59:17 GMT -6
Morning Boys, I have a 150 gy6. If I try and check the oil right after I shut it down I have oil spurting out when I loosed the oil stick. I have to let it sit for a while before I can remove the dip stick. If I have the dip stick removed and start the motor, it will blow A LOT of oil out as it is running. Is this normal?? If not, what do I check??? I have air/oil coming out of the hose that comes from the valve cover. ![](http://img.photobucket.com/albums/v323/hobbles/Judy/Trike/ready%20to%20go.jpg)
Post by hobbles on Aug 1, 2016 4:57:24 GMT -6
rks, those posts are 4 days apart. 1. Afternoon Boys, I still have a problem with it running. I set the valves, got a new carb, new manifold gaskets and adjusted the carb. But if I give it any throttle it dies as you can see. What am I missing? ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) Click HERE to watch. Read more: scooterdoc.proboards.com/thread/12959/motor-quit-running#ixzz4G4oBqHtJ2. Copied from the other place... "Afternoon rks. It would be nice if it was that simple. I can give it throttle slowly and it won't die. It's only when I do it fast. I can ride it down the road ok, I just can't rev it up or take off fast. I used a water hose and checked for air leaks, I flooded it! It only stops when the water hits the spark plug. No vac leaks,,,, that I found. " Read more: scooterdoc.proboards.com/thread/12959/motor-quit-running#ixzz4G4pMHOsq3. jct842, I used a spray bottle and didn't find any change. I really thought it was/is a vac leak so I went with the hose and flooded it. Still no change. cyborg, I checked the diaphragm of the old new carb and didn't find anything wrong with it. Then I changed the diaphragm out with another one I have, same thing. Then I bought a another new carb, replaced the manifold gaskets and ran a lot of water over the carb looking for air leaks, none. Adjusted the carb about 8 times trying different settings, I am back with the setting I ended up the first time I adjusted it, 2 and 1/8 turns out. New fuel filter and it's pumping good fuel to the carb. sillylittleboy, A while back I bought a new carb and noticed a different's in the sound and how it ran with the new carb compared with the stock one that came with it. New carb and switching to the middle gas made a big diff for the trike. www.ebay.com/itm/351696298763?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITcrwford, My new manifold will be delivered today but I really don't need it. After I replaced the 2 gaskets I have no leaks anywhere near the carb. That I'm sure of. When I flood the motor with water, it only changes idle and stops when the water hits the spark plug. I have also sprayed/flooded under all the side panels looking for vac leaks. I know this problem is something simple that I am over looking. Read more: scooterdoc.proboards.com/thread/12959/motor-quit-running#ixzz4G4pihb3K
Post by hobbles on Jul 30, 2016 9:20:06 GMT -6
It runs good going down the road, good pickup. It might be a jet needs changing. Ahh heck, it runs good, I think I will just leave it alone and ride it. rks,, I'll stay out of the water,,,,,,,,, ![(rofl)](//storage.proboards.com/3059616/images/UdZWLQdgsIWX5Li7LQdC.gif)
Post by hobbles on Jul 29, 2016 13:48:58 GMT -6
Post by hobbles on Jul 29, 2016 3:43:51 GMT -6
Morning Boys, jct842, I used a spray bottle and didn't find any change. I really thought it was/is a vac leak so I went with the hose and flooded it. Still no change. cyborg, I checked the diaphragm of the old new carb and didn't find anything wrong with it. Then I changed the diaphragm out with another one I have, same thing. Then I bought a another new carb, replaced the manifold gaskets and ran a lot of water over the carb looking for air leaks, none. Adjusted the carb about 8 times trying different settings, I am back with the setting I ended up the first time I adjusted it, 2 and 1/8 turns out. New fuel filter and it's pumping good fuel to the carb. sillylittleboy, A while back I bought a new carb and noticed a different's in the sound and how it ran with the new carb compared with the stock one that came with it. New carb and switching to the middle gas made a big diff for the trike. www.ebay.com/itm/351696298763?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITcrwford, My new manifold will be delivered today but I really don't need it. After I replaced the 2 gaskets I have no leaks anywhere near the carb. That I'm sure of. When I flood the motor with water, it only changes idle and stops when the water hits the spark plug. I have also sprayed/flooded under all the side panels looking for vac leaks. I know this problem is something simple that I am over looking.
Post by hobbles on Jul 28, 2016 17:21:15 GMT -6
"Afternoon rks.
Post by hobbles on Jul 27, 2016 14:06:04 GMT -6
Post by hobbles on Jul 24, 2016 5:55:02 GMT -6
Question,, I went out this morning and it started right up but if I give it throttle, it dies like this. ClickyAfter it ran for 5 minuets at idle, it died and it won't start again. Does that sound like I need a valve adjustment??
Post by hobbles on Jul 23, 2016 16:57:58 GMT -6
I can get it running now and again but can't give it any throttle with out it dying. Now it's hot from running for about 5 minuets and won't start. But I did get the manifold leak fixed.
Post by hobbles on Jul 23, 2016 16:16:46 GMT -6
Ok boys, I don't know where to start. I was on my way into the big city today and I didn't make it. As we were going along the trike motor fell flat on top end. I still had low end power and we got it home. I went looking for air leaks. I put water on the intake manifold and it would stall. I did that 3 times, then it would not start again. I have gas going to the new carb and I have spark to the plug. I think I fixed the intake leak but can't know for sure till I get it running.
Where do I start looking for the problem??
It's a GY6 150cc on a 2009 ice bear cruiser.
************UPDATE************ It started running and ran for about 15 seconds then quit again. But it did start. Kinda sounds like it's running out of gas, KINDA. I tried to give it throttle but it dies. Now it won't start again. I already called it a BUNCH of names, what's next??
Post by hobbles on Jul 23, 2016 8:59:53 GMT -6
This problem fixed, can't delete the post, Next problem on it's way
Post by hobbles on Jun 19, 2016 18:12:58 GMT -6
When I cleaned my carb, I found all this in the float bowl. ![](http://img.photobucket.com/albums/v323/hobbles/Judy/Trike/float%20bowl.jpg) I cleaned all the jets, took an air hose to it but it would still stall on me. I was lucky one time and found the sweet spot at about 4 MPH where it would run and got it home.
Post by hobbles on Jun 19, 2016 17:49:04 GMT -6
Evening scooter18, Mine was doing the exact same thing. Now yours could be an air leak like you think, mine was the carb. I just got a new one for the trike for $23 or $28 off ebay and that fixed it.
