Post by metalman35 on Jan 26, 2015 17:30:57 GMT -6
YES !! on the road again... was small piece of plastic in there that I had to pull out with tweezers. that's why first time when I sprayed it down and blew it out didn't fix it..THANK YOU !!
Post by metalman35 on Jan 25, 2015 18:22:35 GMT -6
Followed video for adjusting valves and for cleaning carburator.....had a little trouble initally starting but got it running at fast idle, let it run 30 mins. while i reassembeled seat.adjusted idle back down and let it run a while longer then shut it off while i grabbed jacket... wouldnt start at all...30 mins. later started only with throttle wide open but idled normally after. took it for short spin around block.....parked it ...hour later go back in garage and fuel all over floor steady dripping out of air cleaner.
Post by metalman35 on Jan 25, 2015 12:55:36 GMT -6
used daily for several months by daughter, was low on oil so she filled it (completely full till spilling out).went to work next day and would not start after. I drained oil down to fill line, pulled spark plug and cleaned it(was dry) sprayed down carb with cleaner. Also may be important to know we have been kick starting for long time because batt dead?. anyway it is very difficult to get it to start then wont idle for more than few seconds(tried adjusting idle screw), if I give it gas it will run longer if I rev it up and down but ends up bogging down and stalling after 30 seconds. After last time gas is steady dripping out of air cleaner ?
