Post by kauairyder on Feb 14, 2015 20:07:06 GMT -6
unplug the regulator and see if the lights go out . John Thanks john, I wasn't able to see the front lights because I disconnected the bulbs, but the rear light was on and when I disconnectedthe regulator, the light went off. Do you think that ythe regulator burnt out?
Post by kauairyder on Feb 14, 2015 18:47:30 GMT -6
I may have for a moment. How can I trouble shoot the black wire to see if its the cause can you post a picture of your regulator ? Not sure how to attach photo to here. There is green yellow white red coming off regulator
Post by kauairyder on Feb 14, 2015 18:45:23 GMT -6
At this point we need your wiring config. Do you have a yellow and white wire coming off of your stator? Do you have a wiring diagram in your manual? As suggested by the guys, you may have roasted your R/R and blown a diode. That would explain the charging loss. The relay theory would explain the headlight on all of the time but that would be unusual on such a small engine and especially a Jonway. So some pix of the stator and R/R wires would help. Yes, there is a yellow and white wire coming off the stator. Where should info from there
Post by kauairyder on Feb 14, 2015 18:33:15 GMT -6
did you invert the battery cables (for a moment) ? The regulator is shorted internally , this is the item that is most likely the cause , it could be black in color . John I may have for a moment. How can I trouble shoot the black wire to see if its the cause
Post by kauairyder on Feb 11, 2015 21:17:13 GMT -6
Hi, the most likely culprit is your headlamp relay. It was likely arced into a closed loop (means always on) circuit when you installed battery.... When you install a battery, it's essential that you hook up the positive cable FIRST. Do you by chance have a wiring diagram? If not, what is the exact model of your scooter. I was just informed a lot of the scooters do not have a relay for the head lamp. If it's not a relay, it may be a faulty switch....jonway yy50-qt-6
Post by kauairyder on Feb 11, 2015 21:14:33 GMT -6
I did, the first time, have the neg. cord on the positive side and did connect the pos. first. My negative was partly red, from past owners, this caused my first short. What is the best way to test the headlight rely? can I replace the rely on this scooter?
Post by kauairyder on Feb 11, 2015 1:13:42 GMT -6
Bike starts normally once started. Ran the bike, light stays on and eventually ran the batt low. Needed to kick the bike over.
Post by kauairyder on Feb 11, 2015 1:12:20 GMT -6
No it doesn't. Speedo and gas gauge only come on when key is turned
Post by kauairyder on Feb 6, 2015 18:01:14 GMT -6
I have a 50cc Jon way that I recently R2 my batt. When I first put the batt in, it blew the positive fuse. I R2 the fuse and connected another new battery to it. When I connected the batt. it sparked once the positive touched the terminals. Then, the head light stays on without the key in the ignition. Prior to this, there were no issues with the bike. I am stuck with this issue. Can anyone help or suggest anything.
