Post by mrk610 on Apr 13, 2015 14:26:51 GMT -6
Guitarman why a major night mare. Checked all connections and they are all clean and tight. Finally got the PDI done . All fluids changed and new silicone vacuum lines and fittings. Kinda up in the air about the fuel pump and the fuel lines. will probable keep the vacuum pump for now. As for the fuel lines they look in good shape not as bad as vacuum lines where. Had a PIA time flushing the coolant. I could not get the system to burb the air out. Ran scoot and let temp get up to 3/4 , top rad hot bottom cool so I know I got a big air bubble in the rad. First took the top hose off filled with coolant. Ran and same symptoms . I'm like here. So I sat back and thought why will the system not burb. I finally took the small hose in the center of the top rad tank off and it was clogged with gunk. Blew that clean and started over again. Scoot heated up burped and fan came on at 1/2 gauge. The coolant that came out was like mud nasty brown reddish color. I flushed the system 4 times with clean water. Now have to put the scoot back together and take for a ride. Mike K in South Jersey .cked all connections and they are all clean and tight .
Post by mrk610 on Apr 8, 2015 11:17:31 GMT -6
Post by mrk610 on Apr 8, 2015 11:13:59 GMT -6
Pics
Picked it up on coldest and snowiest day of the year .
Post by mrk610 on Apr 8, 2015 11:11:26 GMT -6
Hi all late joining the scooter world . Got my scoot from N J craigslist for 1000.00 and only 492 miles on it. In the middle of doing a full PDI have it stripped down and waiting on parts to come in before I put her back together. Have a couple of questions here. What is a good bulb to use for the head lights. I have the original 12v 25w/25w now been looking at the same bulb on Amazon but 35w/35w any ideas. I have been really pouring through the forums and just wondering if upgrading the fuel pump is worth it. I would also like to add a little volt meter to keep an eye on the charging system . I'll try to post some pics.
Mike from South Jersey
