Post by scootdr on Mar 3, 2015 20:46:31 GMT -6
I am lead to believe it is split because only the headlight is not working everything else is except the charging of the battery.
Post by scootdr on Mar 3, 2015 18:13:51 GMT -6
Thanks for the help! :(That is what I was thinking "rectifier" right? I am waiting on my Multi-meter (zzz)to find its way home. When i get it I will check my VAC at the stators plug Do you happen to know the proper Vac for a 157?
But....doesn't the main headlight burn AC?... its the stator if so right?
Post by scootdr on Mar 3, 2015 16:06:50 GMT -6
I have a newer model VIP 150cc with a 157QMJ that has all DC lighting but my Charging system is down (AC) no headlight or Charge yet engine will run fine. Simple right??? Please help as I am having a hard time is it the stator or something simple?
