Post by dennis on Aug 13, 2016 11:52:39 GMT -6
Another note the front and rear sit much to high. Bad geometry. Like jacking a truck up with out suspension mods. what did they do? to cope steering dampers. Next would be to get the control arm mounted correctly or lower the scoot to bring them just above level with the pavement. Spring rates for front and rear are not correct either but l have not calculated those yet. Lowering the trike will help it handle much better for many reasons but not good for of roading if thats what you want. I have not calculated roll center yet either so as can tell my scoot is a work in progress. I find your inputs very help as to what trouble to avoid. Thanks to all. Dennis
Post by dennis on Jun 18, 2016 21:52:34 GMT -6
Have gotten no response on my last post so l will respectfully ask if any one here has ever heard of or know any thing about the DA shun carb. that is installed on some of the China scoots. Sincerely DT PS I am looking for jets.
DA shun carbs
by: dennis - Jun 17, 2016 14:47:00 GMT -6
via mobile
Post by dennis on Jun 17, 2016 14:47:00 GMT -6
I am trying to increase the main fuel jet from a 110 to a 125 on a DA sun carb. Does anyone have experience sourcing jets for this type of carb? Thanks for any help. Dennis
Post by dennis on Jun 2, 2016 16:30:38 GMT -6
I just found your post. I have had one since early spring, l don't find anything bad about it other than normal things most of us have found with other scoots on this sight. The fellow that said forget it is just mistaken. I have found nothing out of the regular pains. I have found frames and most any thing l would want or need,just had to look around a bit and found several suppliers.Have fun and enjoy it. It should be OK like most of the China scoots.
GY6
by: dennis - Jan 5, 2016 22:19:34 GMT -6
via mobile
Post by dennis on Jan 5, 2016 22:19:34 GMT -6
I can not tell you what the numbers on the case are just now.I can tell you it is a Wild Fire WF195. I also know the guy that was was selling these out of buss. I also found a company out in California that is marketing them. Are the drive trains different carbs cams? I have found no dif. between other engs.So can anyone tell me any thing about this scoot without the numbers. Thanks for any helpful info.
GY6
by: dennis - Jan 2, 2016 10:19:17 GMT -6
via mobile
Post by dennis on Jan 2, 2016 10:19:17 GMT -6
To all.please tell me what you might know about the engine from 2008 that is labeled on one of its tags 174.5 cc. I have not seen a gy6 with this cc in my experience. Thanks for any and all help.I should say that I would like to know about such things as but not limited to performance parts, including gearing, stroke,better intake manifolds,carbs etc.I would like to increase top speed 5-10mph as a primary goal. Thanks again D.M.T.
Post by dennis on Oct 28, 2015 18:59:41 GMT -6
Hi Ya Just saw your post about the probs and the one about the wheel. Are you still trying to resolve the prob,given up or figured it out? Please let me know. I am an owner and am tackling some of those problems.
Post by dennis on Oct 8, 2015 19:50:07 GMT -6
Bill trek Good on you!
Post by dennis on Oct 8, 2015 17:22:47 GMT -6
With all the iron you have and the cars and trucks you have driven I have great respect. I use to drive semi truck and motorcycles oh and roadraced formula cars as well as sedan cars like the one in the pic,except mine was modified for roadracing. I guess from having been an instructor for semi truck driving when I was 21 to roadracing instructor at 25 and competing for thirty five years in cars etc.it is just my nature to care big fella. Good luck.
Post by dennis on Oct 8, 2015 12:10:37 GMT -6
I would also suggset getting rid of the glass fuse. The mini spade makes a better connection than that cheap fuse holder and you can get one that is "water tight". By the way don't forget to use dialectic grease on all connections. It protects against moisture. Many years of dealing with British cars has taught me much about 12 volt electrics. Lucas,father of darkness
Post by dennis on Oct 8, 2015 12:01:05 GMT -6
After reading all of this, would it not be a good idea to come up with a modification that anyone could do that would split out the different systems into a fused curcuit of there own? Wouldn't that help protect against such things happening? Just a thought. If I put this in the wrong place would someone move it. Napa sells fuse boxes in a range of prices and wire etc to do the job.
Post by dennis on Oct 7, 2015 19:57:37 GMT -6
You said you are going to just go out for short slow rides is what I got. So keep it to that the thing won't run as fast as a 150cc scooter with that engine and all that weight. I will say that a good deal it was for around town bike. you might want to go to a riding school for side cars they are very different than a two wheeler.
At output
by: dennis - Sept 25, 2015 15:33:51 GMT -6
via mobile
Post by dennis on Sept 25, 2015 15:33:51 GMT -6
I will be testing it as soon as l have it back on the road. Thanks guitarman for the imputed on the output,ha ha. I look forward to updating everyone on the results of the mods l am making. Thanks so much. Dennis
Post by dennis on Sept 25, 2015 9:57:04 GMT -6
All I just called Jim at Rapid Repair. He was most helpful. Please ignore any post I have done on the subject. Thanks so much. Dennis
Alt. Output
by: dennis - Sept 25, 2015 7:40:38 GMT -6
via mobile
Post by dennis on Sept 25, 2015 7:40:38 GMT -6
Thanksfor responding. The soot is a 300cc Sunny, 2012 model year. Thanks so much. Dennis
