Post by leeroyjenkins on May 19, 2015 18:32:05 GMT -6
I'm back to square one. I took it for a test drive and shredded the belt. I ordered a new kevlar belt and a clutch assembly. Oh well. I'll be back running on Thursday
Post by leeroyjenkins on May 19, 2015 16:17:32 GMT -6
I'm up to 6500 miles. I was having the squealing noise so I took the clutch apart, sanded the pads and the bell. The squeal is 98% gone. The pads looked okay to my untrained eye. How long do they typically last for? I'm borrowing an impact wrench so if it needs to be changed I have the right tools for the job at this moment.
Post by leeroyjenkins on May 16, 2015 10:33:25 GMT -6
Is it a 50cc?,,,once you get the bearing issue solved I'm thinking 35-40 on a good day I think it's a belt not a bearing. It squeaks at idle and gets louder under load. The guy before me said he replaced the belt recently but considering he sold me the scoot for $80 to pay off a payday loan...I'm sure it wasn't a high quality belt. I wouldn't be surprised if he bought it at old navy.
Post by leeroyjenkins on May 16, 2015 10:31:43 GMT -6
LOL,,it just sunk in $80 for a whole scoot!!!! ,,, wow,,,what's the running total? $200?? Yup I'm at about $200 total. I put about 50 miles on it this morning. I live on the beach so I think wind has a lot to do with my top speed. Into the wind I'm averaging low 30's with a tail wind I've seen 40. I have a lot of draw bridges around when going uphill it struggles to maintain 25 but down hill....I've hit 45
Post by leeroyjenkins on May 15, 2015 15:21:12 GMT -6
How fast is it supposed to go? I'm 6'2 200lbs and got it to about 32-33mph.
Post by leeroyjenkins on May 15, 2015 15:20:07 GMT -6
I knew you were going to say that. I just replaced the back tire this morning. Had it off with the exhaust. I'm going to putt around this weekend and try to pin point it. I'm just amazed I paid $80 for this thing and got it running in a day.
It only needed an oil change, new spark plugs, new bulbs, new mirrors, new brake handles, a rear tire, and a good cleaning.
Post by leeroyjenkins on May 15, 2015 15:06:47 GMT -6
Thanks for the help guys. I got it working. My real issue was a broken brake handle. I fixed that and now everything works.
I took it out for my first test drive, everything sounds good. There's a dull grinding sound. I'm 99% sure its the bearings. I read the manual and it said to grease with white lithium....but I don't see how to access the bearings. Any thoughts?
Post by leeroyjenkins on May 14, 2015 20:58:40 GMT -6
Thanks for your help!
I'm going to hook it up in the morning. Fingers crossed it works.
Post by leeroyjenkins on May 14, 2015 19:26:24 GMT -6
Can you explain the wiring of the bulb. There is a wire that goes directly to the side of the base (green on the connector) I assume that's the bulb ground. Then the green/yellow and brown go to the two posts on the bottom of the bulb.
Post by leeroyjenkins on May 14, 2015 18:48:15 GMT -6
Hello all,
I just picked up a new to me Bintelli Sprint. The scooter runs fine but it was having an issue with the tail lamp. I purchased the new wiring harness and when I match colors up I can not get it to work correctly. There are three wires. Brown, green/yellow, green. I hook them up to the right colors but when I hit the brake the light goes out, when I take my hand off the brake the light is one. What am I doing wrong?
