Post by cruiser66 on Sept 21, 2015 22:51:33 GMT -6
Like Alley says, the age and how well the cooling system was maintained is important. This particular type scoot is prone to overheating and needs all the help it can get. You might also want to check the thermostat to make sure it's not sticking. The temp gauge should also be repaired so that you can check to see how well the work on the cooling system is doing.
