Post by yaj on Sept 24, 2015 22:26:11 GMT -6
I was able to get the Flasher from the link you provided and the Blinkers work now so thanks . Another problem did crop up tho I was hoping you could help me with. I had taken apart the scooter previously to get the pictures of the insides. Taking apart the cable that connects to the speedometer took awhile. I had to be somewhere quickly and I used the scooter with out the cable attached. So while i was driving the speedometer wasn't working. Then half way coming back my main headlight (which had been flickering every time I switched from high beam to low beam) Just went out in the middle of the road. So my Light didn't work I tried to push connectors together if anything was loose, but to no avail. Is it possible its connected with the speedometer cable not being connected? Thanks again for any help it means the world.
Post by yaj on Aug 27, 2015 14:40:34 GMT -6
Thanks alot for the help alleyoop. Trying to track down the part now. You have been a huge help much appreciated.
Post by yaj on Aug 20, 2015 6:37:46 GMT -6
Scooter had just gotten out of the shop was getting ready for my first ride. Everything was working fine. Lights good. Blinkers check. Horn check. But shortly after I honked the horn. I was double checking blinkers and they didn't work. I did my first ride with out them using my hand to signal. Today I got up and did some research. I opened up the front and the top of the cover's for the moped and tried to push any wires together if there was a loose connection. I started it up again and the blinkers still don't work. These are some photo potato quality sadly. imgur.com/a/pfhjO Can anyone help?
