Post by javid234 on Apr 22, 2020 5:53:28 GMT -6
Yea the needle is good, it’s only the single position type... and it’s all clean ... I’m wondering since it was stored in a fairly damp location, if the moisture did something to the electrics In the ignition system..... could it be ? The only other time a had a motor act similarly, was an exhaust restriction... but I pulled the pipe and it seems clear. This motor did run a tad lean before ...”pod filter” but never popped or or did this ... it was just hard to start
Post by javid234 on Apr 21, 2020 17:56:32 GMT -6
Yea I checked the jets .. clean as a whistle, i even tried drilling it out a little...still didn’t change a thing. It’s very odd... it never ran like this before storage ... cleaned it all up and set everything the same as it was. And now this... I can’t find any air leaks or pin holes in diaphragms, vacuum lines are still soft and pliable, valves are good compression is good.... I’m stumped
Post by javid234 on Apr 21, 2020 15:33:49 GMT -6
I looked them over when I removed the carb. I didn’t see any issues in the diaphragm or intake... I set both valves to about .004 but no changes.. the slide was pretty corroded but I cleaned it very well, until it would move freely ... it barley makes a difference weather you have the air filter on or off... I can see the slide move clearly when I rev it, but as soon as the vacuum slide opens wide it Boggs...it Seems to rev a little higher with the filter off, but I don’t know why that would be... because it still pops when you roll off the throttle like it’s running lean. But if I restrict airflow it runs even worse ...
Post by javid234 on Apr 14, 2020 10:30:31 GMT -6
Hi guys first post here. I’m a decent mechanic and have worked on motorcycle for years, but can’t seem to figure out this simple scooter. I bought it for my wife years ago and it allways started hard. But once it was running ran great! Sadly we didn’t use it much and it was stashed in a backyard shed for probably the last 4 years, without being run. The shed was damp, and unfortunately the kill switch/starter button and blinker relay no longer work... I cleaned the carb very well and started it by crossing the starter solenoid .. and the scooter starts much easier than it used to oddly. But now if I twist past 1/2 to3/4 throttle it Boggs and stumbles like crazy, if I roll on easy it will rev much higher but if I roll on fast it stumbles almost right away..it used to carry me 50mph no problem not 30-35 is about max.. I thought maybe it was the carb running to lean or rich so I pulled the air filter off and it barley made a difference, so I tried covering up the filter a little and it again Made little difference. (Just trying to tell if it’s mix related or not) I’ve always been pretty good at playing with carbs and I feel like it’s not carb related anymore.... any ideas what would cause this ? This is a video link of the scooter revving on a stand.
Post by javid234 on Sept 21, 2015 17:15:07 GMT -6
k ill try your suggestions and don't worry I wont run it without a filter. could it be from not having a stock airbox and only having a UNIfilter ?
Post by javid234 on Sept 19, 2015 15:52:12 GMT -6
hello all today I purchased a rocketa scooter with a 150cc big bore kit GY6 engine it didn't run great when I bought it but now it runs worse and im not sure what to do the air box is removed and it has a unifilter cone filter on it when I bought it there was also a cloth wrapped around it. they said it was to make it "run richer" which doesn't seem like the best way to go and I thought that was probably making it run poorly so I took of the cloth and it ran great for a bout a mile it actually reached 55-60 and im 220lbs and then as I was running at 60mph it tried to stall I let off the gas and feathered the throttle and limped it home but ever sence it doesn't run worth beans! any ideas ? im new two scooters and 4strokes I ride 2 stroke dirtbikes mostly so im lost
