Post by iceman0 on Oct 19, 2015 20:43:08 GMT -6
Long case. Forgot belt size but original. Scoot soon to be 163cc with some other add ons so not going to be stock with a 30mm carb.
Post by iceman0 on Oct 18, 2015 21:11:34 GMT -6
Ok think I'm set correctly now it's grabbing around 2k and I'm above 6k. Should I get one of those 30mm carbs with accelerator pump? I'm not familiar with the 28mm mikuni cvk that came with spare 150 i have. There are 3 jets in it and it's missing the pilot jet. I don't know jet sizes to go with to start. Not much info.
Post by iceman0 on Oct 16, 2015 14:57:40 GMT -6
According to the tach I'm engaging between 1200 and 1500. I thought I tried the multispark setting but I'll try again. I ordered a new set of 12g rollers but when I put the stock ones back in the scooter seemed like it was studdering. I'll play with it more before I start any engine mods. I have a mikuni 28 cvk someone gave me but it was missing the pilot jet. Anyone have a idea or recommend a carb. Thanks Ice
Post by iceman0 on Oct 16, 2015 10:26:45 GMT -6
The kit came from gy6 racing in Puerto Rico along with the exhaust that looks exactly lIke a two brothers. I have the cheap ebay tach on it. I was thinking the tach was set wrong so I double checked and it's set on 1. The clutch is engaging above 1000. Isn't that correct?
Post by iceman0 on Oct 15, 2015 7:35:21 GMT -6
I have the qmj engine first off. I installed a tach, blue cdi and changed out the variator to a koso with 9g rollers. I didn't really gain or loose anything.I'm only able to get 3800rpms or so from it. The seller claims it has no rev limiter. I have a 60mm high compression BBK with all the head tricks and cams along with a beautiful dmc exhaust waiting to go on. Another question is carburetor. Should I go with a cvk or a pwk flat. Any help would be great.
I'm only a newb to the scooter community.
Thanks Ice
